05-17-2010, 06:50 AM
1973 29' Ambassador
1985 25' Sovereign
2008 19' International
Franklin
, North Carolina
Annoying Mystery Leak
05-17-2010, 07:11 AM
West of Fort Worth
It may not be the door seal at all.
In looking at your photos, it looks like you have several possible leaks other than the seal, all involving rivets.
There is the vertical rib to the left of the door, around the door, the door hinge rivets and the rub rail below the door.
The door seal does look deformed as viewed from the inside photo.
Good luck,
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
05-17-2010, 07:49 AM
1977 Argosy 24
Milltown
, Wisconsin
I would also check where the awning attaches and make sure the screws or rivets aren't loose.
05-17-2010, 08:46 AM
2010 28' Flying Cloud
Escondido
Seal the door with tape and see if it still leaks. I'm betting on the awning attachment point, probably needs resealing.
05-17-2010, 08:50 AM
1973 29' Ambassador
1985 25' Sovereign
Franklin
, North Carolina
I also though it could be coming from the rivets in the door. This weekend I drilled out and replaced the rivets in the door hinge. Before replacing the unit I siliconed around the holes between the door frame and the door hinge. I will check the panels and rivets this afternoon down the seam and around the awning. If I find cracks in the panel seals what kind of sealant do I use? Vulcum?
05-17-2010, 05:39 PM
1971 27' Overlander
Central
, Ohio
I'd agree with trying that also - just the door gap with painters tape. The gasket on the door is on there incorrectly (mine were that way also). If your going to use that gasket the flare edges need to point into the opening. I do not like the new D gasket on the windows but I do on the access doors. You can order it from Inland or your RV dealer should have it on long rolls they can cut to length. Good luck .... leaks suck...
05-17-2010, 06:25 PM
Central
, Mississippi
If yours is made like mine, the channel inside the wall has an upward facing "C" that can collect water from FEET away. The inner section of the "C" is notched away just about where your water is appearing, that is just where the water is dumping out of the channel.
Have fun...one of my leaks was a rivit in the frontrock guard and it was running 2 feet to that location.
How about lowering the nose WAAYYY down and seeing if the leak moves, then lifting the nose likewise. Atleast that will narrow down the direction the water is coming from. If dropping the nose works, the leak is fwd of the slot...
05-18-2010, 05:56 AM
1973 29' Ambassador
1985 25' Sovereign
Franklin
, North Carolina
I sealed the rib to the left of the door, sealed and re-tightened the awning supports and sealed the first top curved rear panel adjacent to the rib to the left of the door. Last night we had a down pour and the leak (however smaller, I think) reappeared this morning. Looks like I will start on the starboard side and go over it with a fine tooth comb.
Nothings ever simple!
05-18-2010, 07:50 AM
Escondido
Try checking all the rivits/screws at the rail that the awning connects to. could be running down from the top.
05-18-2010, 07:59 AM
Port Orchard
How can one tell from the outside, if a rivet is leaking?
Ken
05-18-2010, 09:31 AM
1973 29' Ambassador
1985 25' Sovereign
Franklin
, North Carolina
I noticed that the top of the rub rail has sealant, however the bottom does not. Should it? The floor appears to be on the same level as the rub rail but not sure if it could run under and penetrate through the wall. It really looks like (to me) its coming through the wall. The wall and seal on the inside are dry as a bone. Yet the spot on the floor is wet and I mean saturated like a slow steady drip.
I agree w7ts.
I will check all the panels tonight on the curb side for cracks and look at every rivet (if I dont go crosseyed) and apply sealant anywhere I think an issue could arise.
05-18-2010, 01:53 PM
2022 25' International
Savage
Check the awning mount just left of the access door. That is a common leak spot. Note that water may be running in the wall where you cannot see it, coming from who knows where. I would start sealing everything above and to the right and left of where the water is showing up.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
05-18-2010, 05:06 PM
Port Orchard
Ken
I think maybe some may thought I was questioning the post I quoted. However this was a serious question. Are there any tell tale things to look for in identifying a leaky rivet. Obviously loose is one.
regards,
Ken
05-19-2010, 06:13 AM
1973 29' Ambassador
1985 25' Sovereign
Franklin
, North Carolina
Stopped by the local Walgreens on my way home and picked up a couple of syringes to help with the finer sealing areas. I'm not an advocate of just squirting sealant on the side of the camper. I think I found the problem area in the window frame just above the access door. I didnt find any loose rivets, but did find 2 that were kind of in sideways that left a gap wide enough that I could force my finger nail under. When I finished I had re-sealed almost the entire curb side of the camper. Good news: there wasn't any fresh leakage in the camper this morning, bad news: it was a very light dew last night. I will post more as time goes by.
05-19-2010, 08:30 AM
1977 25' Tradewind
Waskesiu Lake
, Saskatchewan
Lesson we can all learn from rc707... persistence, persistence and more persistence.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
05-20-2010, 08:09 AM
1973 29' Ambassador
1985 25' Sovereign
Franklin
, North Carolina
Still dry
Waiting a couple more days before I lay the floor.
05-20-2010, 08:44 AM
Savage
Originally Posted by rc707
Still dry
Have you tried hosing it all down with water? All the areas you caulked? This might fast path finding any left over leak.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
05-20-2010, 03:17 PM
1973 29' Ambassador
1985 25' Sovereign
Franklin
, North Carolina
Not yet. Doing a lot of stuff with the house now. Next opportunity to work on the AS will be Sunday. If no leaks have occurred between now and then I will break out the hose.
05-28-2010, 07:35 PM
1973 29' Ambassador
1985 25' Sovereign
Franklin
, North Carolina
In my last report I was going to work on the unit the following Sunday. Sadly I was unable to and was called out of town the whole week. Upon return, I inspected the A/S for leaking as it rained several times while I was away. I can happily report no leaking had occurred during my absence. I feel at the point in the project I will be giving the green light to move forward with laying the hardwood floor. Before I close this post I would like to thank everyone who responded with words of wisdom to helping me diagnose the problem.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Mystery Leak
moosetags |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
1 |
07-08-2007 05:38 AM |
Water leak mystery...
TennisMan |
2007 Safari SE |
1 |
06-03-2007 06:40 PM |
Annoying GM ad
streamer23 |
Forum Admin, News and Member Account Info |
43 |
10-31-2006 12:37 PM |
Mystery Leak
Excellaphant |
1987 - 1989 Excella |
10 |
12-21-2005 08:57 AM |
Mystery coolant leak
PeterH-350LE |
Mechanics Corner - Engines, Transmission & More... |
11 |
06-06-2005 11:34 PM |
