Old 10-19-2019, 10:49 PM   #1
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
Am I Using the Right Sealants?
Hello Everyone, thanks for stopping by.
I wanted to collect everyone's opinion on the sealants I am about to use.
I am in the process of sealing everything that I can on my '72 Ambassador, starting with the roof and working my way down.
Sealants of choice that I have, according to my research on here are:
- 3M Sealant Tape #4412N. This sealing tape I am using on all my roof vents.
- Sikaflex-221 in Grey to seal up all gaps on windows, doors and trim.
-Parbond clear I will use to seal where the aluminum overlaps. By this I mean where the body panels vertically overlap. Is this something that needs to be sealed?
Parbond is the one I was wondering about. From reading on VTS, this is used to seal gaps that are less than 1/8" which would cover the vertical overlap of the aluminum panels. Am I correct?
Any and all comments are greatly appreciated.
Swrider is offline   Reply With Quote
Old 10-20-2019, 07:34 AM   #2
1966 22' Safari
Fredericksburg , Texas
Concerning the Parbond, I believe it does the job. On all exterior aluminum panel lap joints, I squirt Captain Tolleys in the joints first. It has capillary properties and wicks into the joint. Then I use painters tape and tape each side of the joint. I squirt the Parbond in and smooth it with mineral spirits. I use the silver so I can see that the joint is sealed. Parbond is messy so I go the extra step with the 3/4” painters tape. No issues so far. Good luck
Bubba L is offline   Reply With Quote
Old 10-20-2019, 12:53 PM   #3
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
Thanks Bubba, gotta get it sealed up soon. Not because we get a lot of rain in thebdesert, but the temos will be dropping below recommended for caulking soon.
Old 10-20-2019, 02:57 PM   #4
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Nothing to do with any specific sealant or tape: You need to be pretty sure the surfaces involved are clean. Oil is bad, silicone spray is worse in this respect. Avoid any sort of lube around an area you are about to seal !!! Solvents can take off (most) petroleum based materials, just about noting on earth will fully remove silicone lubes.
Old 10-20-2019, 10:00 PM   #5
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
There is also a Thread called Sealants Summery in the exterior restoration topic area that might be useful.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 10-21-2019, 10:48 AM   #6
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Below is a link to the Forum Sealant Summary - this should be helpful.
airstream-maintenance-sealants-summary
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
Blog Languages: English/French/Spanish
drbrick is offline   Reply With Quote
Old 10-21-2019, 12:38 PM   #7
palm beach gardens , Florida
Your AS couldn't possibly have a leak could it?
m rafferty is offline   Reply With Quote
Old 10-21-2019, 09:35 PM   #8
2018 22' Sport
1972 29' Ambassador
Las Vegas , Nevada
Nope, not a single one!!!
I did read thru the entire Sealant Summary, very helpful and informitive.
Caulking and Sealants (silicone, parbond, vulkem & more) Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 266 07-01-2017 12:41 PM
Right sealants on the right sections BoldAdventure Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-22-2014 12:09 PM
Right Rear Tire Wearing on Outside & Right wheels Closser together than left wheels Tnsawdust General Repair Forum 7 04-10-2009 08:49 PM
The right acid works with the right applic got polish Cleaning, Stripping & Polishing 1 07-17-2008 09:50 PM
Eternabond tape sealants Mariner Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 04-08-2004 07:54 PM
