Old 01-30-2011, 03:17 PM   #57
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Steve, thanks for the details on sealants. We remember the Horn of the Moon Cafe with fondness and it closed the same year we were in Montpelier. The cookbooks live on fortunately.
The Fantastic Fans are a continuing problem. The rear one has been resealed two or three times and the front one once. It helped when I resealed from the inside of the rear one too and it hasn't leaked since. The vibration of the fan itself—however small—may contribute to the problem.
Gene
Old 02-18-2011, 06:17 PM   #58
1979 24' Airstream Excella 24
Lake Tapps , Washington
Leaks
I own a vintage 1979 AS Motor home. I have had two other brands of motor homes. Anything can leak, but AS are less prone than others. To give you an idea, I saw a sign at an RV repair facility that said,
"If you think you don't have any leaks, you just haven't found them yet!"
That says it all.
I live in the Auburn, WA area, so I know your rain. Buy what you love and use it. Like Captain Ham Bone says, "God hates a coward!"
I went to Sumner RV for a pressure check. Huge fans pumping air into the roof vents, soap on exterior will show bubbles where the leaks are. Bingo! $75 is cheap for that kind of detective work and worry reduction!
Enjoy and quit worrying.
grandparippe is offline   Reply With Quote
Old 02-18-2011, 06:42 PM   #59
Splitrock's Avatar
Sioux Falls , South Dakota
The guy I bought my trailer from said: "I'd rather have a leak than an electrical problem." But the Airscream gods thought he said: I'd rather have a leak and an electrical problem."
Old 02-20-2011, 07:47 AM   #60
2000 35' Land Yacht XL w/slide
livingston , Texas
I have a leak in the front a/c on my 2000 LY MH. the tech said he never saw caulking on the gasket before. It was so bad he could not break the a/c from the seal had to get another tech to help him. Also very sloppy job.
rvtogo is offline   Reply With Quote
Old 02-20-2011, 09:10 AM   #61
Master of Universe
Gene's Avatar
Yes, all trailers and houses will leak eventually.
But, Airstreams would leak less if workmanship at the factory was better. There are plenty of reports of sloppy sealing and overtorqueing of screws on things like the skylights.
Gene
Old 02-20-2011, 10:27 AM   #62
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Zip Dee
An interesting note is that Zipdee that is all they use to seal around any awning equipment.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 03-03-2012, 03:04 PM   #63
2011 25' FB Flying Cloud
Lac du Flambeau , Wisconsin
New Airstream leaks
Our new FC is leaking and the water is coming in from a seam on the curbside. Not bad, but enough to be concerned.
It's obviously within the warranty period and we will take it to Jackson Center
for repairs within the next month or so. I'm wondering what we can anticipate
at the factory. I'm hoping they identify the leak, assess the damage, repair the damage and replace whatever has been ruined. And, of course, fix the source of the problem. Can some of you please share your warranty repair experiences in Jackson Center?
kickstand is offline   Reply With Quote
Old 03-03-2012, 03:08 PM   #64
Ask them to test the trailer in the "bath house" where all the trailers are tested during the manufacturing process.
It's quite a sight to watch.
Old 07-11-2012, 08:00 PM   #65
1975 31' Sovereign
Plant City , Florida
Send a message via AIM to RayDelfino
I have a 1975. I noticed the front floor was spongy in places. After removing the wood I noticed the insulation was soaked. I caulked all the trimming around the lower edges. There are no obvious leaks but after a heavy rain, water comes in from somewhere and gets the inside of the aluminum flooring wet. Any suggestions?????
What am I missing????
Ray
RayDelfino is offline   Reply With Quote
Old 07-11-2012, 09:00 PM   #66
Splitrock's Avatar
The entire roof, especially the sewer vent(s), roof vents, antenna, air conditioner. Window gaskets, side seam and lap joints, access doors.
Plumbing . . .
Step release slot leaks a LOT.
Vista windows can leak bad.
All the above . . .
Old 07-11-2012, 11:57 PM   #67
195Pilot's Avatar
1975 31' Sovereign
Pierre , South Dakota
Ray,
Check the plywood at and around the door. The plywood holds the door frame in place at the bottom. If the plywood is rotten,soft,spongy at the bottom of the door frame this will allow the frame to recess into the trailer ever so slight and the door will not seal.
As for leaks from the top and around vents, a/c, antenna, you can take the approach one of the po of my trailer. He cured all the leaks. He took approx. 5 gallons of BLACK TAR and mopped the entire top down to the windows. NO LEAKS.
Three weeks of cleaning that mess off and I found 4 prepunched holes in the top skin that no rivets had ever been driven. 37 years after it left the factory.
195Pilot is offline   Reply With Quote
Old 07-12-2012, 05:28 AM   #68
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
I have all the rear interior panels in the bathroom removed in my 77 Sovereign. With out being hooked up to city water or having my water tank in place, I still have running water in the bathroom. It is coming in from the tail lights... Like Niagara Falls! It just needs to be sealed along the top and perimeter of the tail light housing. This spot is what did the most damage to my rear floor.
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 07-12-2012, 07:12 AM   #69
1975 31' Sovereign
I guess I have some work cut out for me. Thanks for all the advice. I'll let you know what happens.
Ray
Old 07-12-2012, 09:06 AM   #70
Splitrock's Avatar
The awning rail can be a source of leaks. When I removed the awning roller from my trailer I found 5 pre-punched rivet holes that never had a rivet.
My trailer had 11 separate and unrelated leaks from the entry door to the front of the curbside living area window. That's only about 5 feet of space. I ended up removing the interior skin to find and fix the leaks. The step release slot is a designed leak. There's no fix for that. My blog shows part of my solution for that issue.
leaks
Have leaks in the new AS... kidsgone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 05-31-2010 11:31 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
How prevalent are leaks in late 70's era airstreams? wacnstac Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 03-03-2006 06:46 PM
leaks maria 1959-69 Tradewind 5 11-09-2005 07:27 AM
Leaks (Again?) Jim & Susan Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 04-27-2005 07:48 PM
