Old 08-20-2015, 03:25 PM   #1
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Airstream Production Seam Sealing Methods
I have a question to all that have previously replaced a OEM exterior panel.
What method of sealing did your encounter?
1) Fillet Seal, where only the overlapping edge of the skin was sealed after the seam was riveted together?
2) Faying Surface Seal, where sealant was applied to the mating surfaces before the seam was riveted together?
Old 08-20-2015, 03:27 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Not to be flippant but sometimes it's more like chewing gum and luck!
At the factory they seal the outside laps, then smear a big wad of goop along the internal seams.
Old 08-20-2015, 03:31 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Newer trailers have #1 on the inside (lotsa gooping) and a black sealant tape sandwiched between them, then a bead on Acryl-R on the exterior joint.
Lance
Top is offline   Reply With Quote
Old 08-20-2015, 03:57 PM   #4
Aerowood's Avatar
Arvada , Colorado
What about the older models, 50's, 60's, 70's, 80's
Old 08-20-2015, 04:05 PM   #5
Mission , Texas
The little bit of seam I saw while replacing a curb side window on our 75 had butyl tape between the layers and Vulkem slathered on the inside.
Sadly the aluminum was slightly wavy from bucking rivets. Maybe it was a bad day for the guy on the factory line.
nrgtrakr is offline   Reply With Quote
Old 08-20-2015, 04:15 PM   #6
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I was speaking of 80s and newer, I guess.
All of the 50s and 60s trailers I've seen have some sort black asphalt type of sealant "applied" to the interior seam.
In the 70s, it is a bit hit and miss. Some seams are sealed on the inside, while others weren't.
I'm not sure what year AS started with the seam tape.
Are you just curious or why do you ask?
Lance
Old 08-20-2015, 05:12 PM   #7
Aerowood's Avatar
Arvada , Colorado
Just curious, I've helped on several and have only come across no sealant in the seam just fillet seals and have heard others say there was sealant in the seams
Old 08-21-2015, 03:45 PM   #8
laducky's Avatar
1978 28' Ambassador
Pacifica , California
On my 78 there's gunk on the inside and a decomposed roll of tape between the aluminum sheets.
Keep on truckin!
airstreamcalledtrouble.blogspot.com
laducky is offline   Reply With Quote
Old 08-22-2015, 09:10 AM   #9
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Kip, I just removed the front and rear panels on my 56, and only fillet seal was used. See here. Hank
See my 1956 Flying Cloud renovation thread.
RankAm is offline   Reply With Quote
Seam sealing from the inside? ironheadxlch General Interior Topics 19 09-04-2015 08:08 AM
Repairs or seam sealing on the top of my Airstream cfishii Ribs, Skins & Rivets 2 06-17-2015 09:42 AM
interior seam sealing GR8DANE Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-09-2013 11:58 AM
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 12:53 AM
Seam sealing - again Fyrzowt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-08-2006 12:01 PM
