Old 11-25-2010, 05:45 AM   #15
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Does a Coleman AC have a drip pan/ MINE JUST RUNS OUT DOWN THE ROOF. vERY MESSY. Sal.
noreen&sal is offline   Reply With Quote
Old 11-25-2010, 06:48 AM   #16
noreen&sal's Avatar
1981 27' Excella II
forgot. Its an 81 Excella II. Sal.
Old 11-25-2010, 09:42 AM   #17
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
We had Coleman's on our 280 and the 310, both had pans and drip tubes. They need to be aired out every season if you're around leaves and pine/fir needles.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-25-2010, 11:15 AM   #18
fmrcaptevil's Avatar
Weldon Spring , Missouri
I just learned this the hard way: if you think your a/c mounting bolts need to be tightened, be extremely careful.....40 to 50 inch/pounds (as recommended by the generic Dometic paperwork that came with my trailer) is WAY too much.......so as usual, Airstreams are different.
fmrcaptevil is offline   Reply With Quote
Old 11-25-2010, 12:20 PM   #19
noreen&sal's Avatar
1981 27' Excella II
where would the drain tube come out of the trailer? Sal.
Old 11-25-2010, 12:30 PM   #20
2002 19' Bambi
Lafayette , California
I don't want to enter into the "no-caulk" question, but only suggest that the present leak MIGHT not be related to the original leak.
Several years ago we had a severe leak from the A/C unit on our 2002 Bambi. Turned out to be nearly invisible cracks in the rooftop plastic shroud. The cracks originated at the screw holes for the screws holding the shroud on. We replaced the shroud with a new one and no leaks since.
Tim
Tim A. is offline   Reply With Quote
Old 11-25-2010, 01:11 PM   #21
lewster's Avatar
Naples, FL , Hood River, OR
I don't use torque specs for tightening a roof air, as almost every situation is different and 'generic' specs are just that.......one size does NOT fit all! The sealing gasket should be compressed to 50% of it's original height to obtain a proper seal.
Old 11-25-2010, 01:18 PM   #22
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
The drain tube comes out in the wheel well. Just look for a few inches of hose sticking down.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-25-2010, 01:28 PM   #23
2007 30' Classic S/O
2010 31' Classic
West Linn , Oregon
Water Leak
Perhaps this will help. My 2010 31D Airstream flooded water when we ran the heat pump...didn't when we ran the A/C. It was repaired in Paso Robles while we were on a trip (two weeks in Paso Robles).
The unit needed to removed and the pan checked to determine the water footprint. My unit had cracks in the heat pan and Dometic unit. Dometic, AS, and Paso Robles had a joint phone conversation while looking at pictures. Dometic replaced the unit. It is important not to use power tools when tightening the unit!!!
I would suggest taking it to a dealer and have them remove and check the the pan. It would be helpful for them to actually see it leak to help trace the problem. It may also leak when running the heat pump. We purchased in August and didn't use the heat pump until late September.
Hope this helps. Paso Robles was super in solving the problem; Jana was Superb! She could also help explain the problem that triggered a unit replacement. Northwest Airstream started the repair and didn't finish it because of our trip schedule being tight. They didn't a wonderful job in coordinating a continuation of the warranty work with Sky RV.
bramer is offline   Reply With Quote
Old 11-26-2010, 10:37 AM   #24
noreen&sal's Avatar
1981 27' Excella II
Drain tube
Thanks for the loc. of the drain tube. Will see if I can blow it out. Hope to be trying it in Jan. in Fla. Sal.
Old 11-26-2010, 11:41 AM   #25
Silver Spud
BillB44's Avatar
2010 23' FB Flying Cloud
Sagle , Idaho
Thanks all. Bramer, ours is purely a rain-related leak. No issues when using heat pump or AC. Just when driving thru heavy rain. (Which happens a lot in the Northwest!) The 'Spud is under a roof now, in storage, but we'll be taking it to an AS service shop (C & G) in SoCal in Jan or Feb to get to the bottom of things. I hope. Will post an update then.
The Silver Spud
BillB44 is offline   Reply With Quote
Old 02-14-2011, 02:23 PM   #26
Silver Spud
BillB44's Avatar
Sagle , Idaho
Leak to be solved this week
If anyone's still following this thread, we're back and this week we take the Silver Spud into C & G Service Center to have them diagnose and repair the AC/roof leak. Will post outcome when we learn it.
The Silver Spud
Old 02-15-2011, 06:48 AM   #27
Yes, looking forward to hearing about it.
Old 02-27-2011, 09:11 PM   #28
tarheelbornbred
tarheel1972's Avatar
1972 29' Ambassador
Wilmington , North Carolina
Send a message via AIM to tarheel1972
I am on the hook to fix my AC/rain leak on my '72 Ambassador. The Dometic AC is a replacement unit that is only a few years old. But during a rain storm, it leaks like a over watered horse.
I can see various suspect seams in the area under the and around unit that I want to attack with Vulkem.
My plan is to unbolt the unit, lift and block the it up high enough to attack all the seams and such. Blocking it up with dunnage.
Any thoughts here?
tarheel1972 is offline   Reply With Quote
leaks
new air conditioner lucca53 Furnaces, Heaters, Fireplaces & Air Conditioning 10 06-25-2010 07:54 AM
Best air conditioner? Bing-Bing Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-21-2009 02:38 PM
Armstrong Air Conditioner Leak michael13 Furnaces, Heaters, Fireplaces & Air Conditioning 7 07-13-2009 12:32 PM
air conditioner air flow problem strawberryjo Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-05-2006 10:43 AM
air conditioner Richard Murphy Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-06-2004 05:48 AM
