Old 09-09-2019, 10:15 AM   #1
1996 28' Excella
Peterborough , Ontario
Adseal for sealing airstream
Just talked to Jackson Centre re Product for sealing Airstream....they use Adseal from UK....has anyone used this product ..thank you in advance
Canoeguy1950 is offline   Reply With Quote
Old 09-09-2019, 10:46 AM   #2
1966 22' Safari
Fredericksburg , Texas
You can read a lot of opinions concerning Adseal on Airforums dating back several years. Good luck
Bubba L is online now   Reply With Quote
Old 09-09-2019, 11:01 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Frankly, none of the sealants Airstream uses come close to the longevity of marine products. My approach has been, "what would I use on my boat?". Not Adseal.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-09-2019, 06:05 PM   #4
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Capt. Tolley's Creeping Crack Cure
Goggle for description. Works great
Jim Flower is offline   Reply With Quote
Old 09-09-2019, 06:06 PM   #5
Jim Flower's Avatar
1997 25' Safari
Google for description.
Works great
Sorry for repeat
Old 09-09-2019, 07:02 PM   #6
1966 22' Safari
Works great
Sorry for repeat
Jim, Tolley’s is a good product. We’ve been using it for years. After I saturate a joint, I tape it off and seal the lap with silver Parbond. Does a great job.
Old 09-10-2019, 09:35 AM   #7
Jim Flower's Avatar
1997 25' Safari
Good idea Bubba. My son has managed to keep the 67 Globetrotter dry with treatment at some offending rivets. The Parbond would be excellent insurance. Thanks for the hint. Jim
Old 09-10-2019, 11:55 AM   #8
2018 27' Globetrotter
Vancouver Island , British Columbia
I read all the negatives comments about adseal in this forum. I talked to airstream and they stand by adseal so I decided to use adseal . I found that adseal is different then other silicone products and it was easy to apply so I have no regrets. I also use extreme tape for the roof
rintintin is offline   Reply With Quote
Old 09-10-2019, 08:41 PM   #9
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I have used Adseal since resealing the roof 3 years ago. it is easy to match when adding to existing adseal when installing other accessories nearby. The real beauty, and some feel it is a draw back, it how easy it is to remove compare to all the earlier sealants used when it is time to reseal. I have not had any loosen upon its own. I guess it could if you hit it too close with a pressure washer. In that case only use an electric pressure washer with pressures around 1400 psi several feet away.
guskmg
Old 09-11-2019, 06:29 PM   #10
CruizinDux's Avatar
Washington , Missouri
Here is the thread bubba referred to.
http://www.airforums.com/forums/f456...ry-116214.html
I just had ours sealed by the dealership. They were using adseal, i asked for the sikaflex721??? white which lewster recommend highly for roof seams. The 221 is more for adhesion and seams as i understand it
CruizinDux is offline   Reply With Quote
Old 09-11-2019, 10:51 PM   #11
guskmg's Avatar
Fort Worth , Texas
I have heard lewster say that AdSeal comes off too easy. However, when it is time to remove the others and reseal (every 5 years is Airstream's recommendation) you are talking a two day job removing and cleaning up the old hard stuff.
guskmg
Old 09-12-2019, 06:48 AM   #12
CruizinDux's Avatar
Wasn't sure if i had the tyoe # right. Here i believe is the most current recap by tintin in post 206. I should add that the dealer loved the 721 for roof sesms and flashing and has changed their goto seal.
Old 10-05-2019, 08:44 PM   #13
Adseal works great.
Old 10-05-2019, 08:45 PM   #14
I did my homework and read all the comments on adseal and I have to say it was easy to put on and it works. It’s not the regular silicone
Adseal To SikaFlex 221, Can Or Should It Be Done? link2dks General Repair Forum 32 11-22-2020 05:58 PM
Adseal or dicor sealant rintintin General Repair Forum 12 02-04-2019 01:02 PM
adseal products dsrtgrls Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 04-07-2018 09:40 AM
Lap seams: Acryl-R or ADSEAL? Bambi in LC Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 09-28-2016 03:33 PM
AdSeal Caulk sailorii General Repair Forum 4 08-18-2015 11:33 AM
