Old 10-16-2011, 06:08 AM   #1
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Angry Acryl-R Plews pump NOT
I can't get the Plews 30-960 pump/applicator to spew.
Background: Bought a can of Acryl-R and Pump from Jackson Center in May. Opened the can and inserted the pump yesterday, October 15. Removed small pin in tip. Pumped until my hand hurt. No Joy. Help?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 10-16-2011, 06:12 AM   #2
Baltimore , Maryland
So it was never used? Virgin can and pump bought a while back? I bet Airstream will allow you to return it. You could also try soaking the pump in some solvent.
Old 10-16-2011, 07:13 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
May be a stupid question - but - just in case. Did your Plews gun come with the adaptor for the can. Cap off can - adaptor to can - gun to adaptor....
You could also try removing the needle tip to see if you can get it to flow. That comes in handy, by the way, when laying down a large bead like sealing the gap between the awning and trailer body.
Old 10-16-2011, 07:29 AM   #4
sd90mac's Avatar
Colfax , North Carolina
Greg, assuming you do get things flowing, you can use the end of a rubber glove wreapped around the nozzle, secured with a rubber band, to help keep the tip from getting clogged by dried Acryl-R.
To try to get the applicator to work, remove the assembly from the can, clean it off, and try using it to pump something not as thick, say mineral spirits. If and when you do get it to pump, get the excess mineral spirits out of it, and re-insert it into the can. It should work, if not, you probably have a bad pump.
When people lie to you, and refuse to honor their word, don't regret trying to follow a dream, new adventures and friends await you.
sd90mac is offline   Reply With Quote
Old 10-16-2011, 07:39 AM   #5
1994 30' Excella
Mississauga , Ontario
As just mentioned try a solvent but confirm that it is compatable with the Acryl-R.
My gun is at my brother's so I can't check but i think it is toluene.
Al
Al and Jean
TAC ON-3
Old 10-16-2011, 07:41 AM   #6
1994 30' Excella
As a side note. I cover the tip with cellophane when not in use and even after a year sitting in the garage it starts right up. That shows how well the stuff works at wicking into joints.
Al
Al and Jean
TAC ON-3
Old 10-16-2011, 07:43 AM   #7
Well Preserved
1993 21' Sovereign
Al
Those pumps are compatible, and are sold with the cans.
Old 10-16-2011, 03:58 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If All Else Fails...
Save yourself $28:
Plews ADHESIVE GUN W/LONG ADAPTER - 570-30-960 - 570-30-960 at Wares Direct
Or at least $18:
http://www.nextag.com/Plews/glue-gun/brand-html
Old 10-16-2011, 08:57 PM   #9
Hansom-Man's Avatar
2009 23' FB Flying Cloud
The Woodlands , Texas
This may be a simple fix. Have you tried unscrewing the black adapter section from the can and re-seating it once or twice? The gasket that forms the seal between the can & adapter is fairly thin, so the can needs to be on really straight & tight. of there's any gap is will suck enough air to not move the rather thick sealant into the pump.
First time I used mine I swore up & down that the thing was on straight. However, when I unscrewed the can and looked at the seal there was only a partial "silver ring" of acryl-r on that seal. After a couple of screwing it back on, the seal set and I was happily pumping away.
Hope that helps.
Hansom-Man is offline   Reply With Quote
Old 10-16-2011, 09:18 PM   #10
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Now you did it.....I had to buy one!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 10-19-2011, 02:56 PM   #11
2011 31' Classic
Images: 8
UPDATE: Thanks for the good advice from all of you. After following most of it, it appears the pump is actually clogged or defective. I can get a smallest amount of sealer through it, but the pump never gets working well. I'll talk with The Mothership about a replacement.
Old 10-27-2011, 06:05 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question gang?
Have got an ongoing leak at the base and lens of two teardrop clearance lights.
After several days of rain they both were 1/2 full. Have tried new lens gaskets and several different sealants nothings worked.
Anyone tried the ACRYL for this? Heard it's a pretty secure bonding sealant and don't want to seal the lens on permanently.
Thanx..
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-27-2011, 07:43 AM   #13
dznf0g's Avatar
Oswego , Illinois
Thanx..
Bob, I have the same situation. I think I will use Parrbond or Vulkem though. I think Acryl R will be too firm a bond when bulb replacemet is needed.
Old 10-27-2011, 09:13 AM   #14
I've tried Sika, but it's not worked very well. Hard to get an even seal under the lens. Slowed the leak a little by putting a very small o-ring around the lens mount screw,(keeps it from falling out too), and sealing around the screw head from the outside. Few more ideas i'm gonna try.
Just how hard does that ACRYL get, is it pliable at all when cured?
PFC
"Tahawus"
RLC
John Prine
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 06:13 PM
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 05:01 PM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 06:56 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 06:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
