Old 10-27-2011, 10:17 AM   #15
dznf0g's Avatar
Oswego , Illinois
Originally Posted by ROBERT CROSS View Post
I've tried Sika, but it's not worked very well. Hard to get an even seal under the lens. Slowed the leak a little by putting a very small o-ring around the lens mount screw,(keeps it from falling out too), and sealing around the screw head from the outside. Few more ideas i'm gonna try.
Just how hard does that ACRYL get, is it pliable at all when cured?
Kinda like hot glue...only more flexible and adheres better?????? Best I can describe.
I wonder about getting some rubber sheet material and using the foam gasket as a template (cut just a hair larger than the foam) and sealing the screw.....? I have some left over rubber roof material from my old SOB re-roof job.
Old 10-27-2011, 10:25 AM   #16
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Did try a 1/8" thick foam sheet, to porous i guess.
Next..an old inner tube.(remember them?)
I was thinking of adding the ACRYL to the tool kit, but if it has a short shelf life and has limited applications maybe I'll hold off and see how the tube works.
Bob.
PFC
but Iím the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-27-2011, 11:58 AM   #17
I was going to cut out all the gaskets....but might as well see if this one does the trick. Just put it in and it's raining now so should know soon.
Hi-jack done now.
PFC
RLC
Old 10-27-2011, 04:29 PM   #18
dznf0g's Avatar
Oswego , Illinois
Hi-jack done now.
I just made 13 of the gaskets out of the old EPDM roof material and got little o-rings for the screws. But it's not forecast to rain this week. We'll see.
Old 07-28-2012, 10:08 PM   #19
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I used Sikaflex on the top edges and side of the rear LED clearance lights that replaced the old bullseye lights. I did this about 4 or 5 years ago and that stuff is still pliable. I also used it, along with 3M tape, to cover the tilt mounts when I place solar panels on my Sovereign 4 years ago. It is still pliable. I have not had good experience with Parrbond because it looked like it was cracking two years after I put it on my aluminum rub rails.
I have a can of Acryl-R and plan to seal panels toward the end of summer so I can't say how well it would work
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Inspecting fuel pump and tank interior DaveFL Land Yacht/Legacy Motorhomes 2 08-19-2011 07:13 PM
PAR pump not working ckbailey97 Water Heaters, Filters & Pumps 9 07-14-2011 06:01 PM
Bad Check Valve in Pump??? tinbender Water Heaters, Filters & Pumps 3 06-16-2011 07:56 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 07:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 08:20 AM
