Old 10-24-2015, 09:49 PM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
AC roof leak
Howdy!
So, after 3 years, no leaks from roof.. Around the main original AC. All the rain the last couple days and we have a leak!
Well, I decided to check torque on the original 1999 AC bolts.. And they are not snug...at all.
Resnugged and no more drip..new axles will resolve the harsher ride we are seeing as evidenced by more "movement" inside of items. We do not get a "shake" like out of balance.. But roughness. Seems like it's time.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-24-2015, 09:54 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I'm glad you fixed the source of the leak so quickly and easily.
Thank you for the reminder to check ours. I replaced the AC seal when I was Eternabond'ing the roof seams in early 2014, haven't checked those bolts since.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 10-25-2015, 07:59 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I haven't checked the bolts of original AC since purchase. Now I know the second AC install required replacement of bolts because the ones they shipped were too small in diameter!!!kept loosening!!! Thanks Lewster for that fix!
Will replace axles before next big trip.
Channing
WBCCI# 30676
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
