Old 10-27-2015, 04:03 PM   #1
1999 34' Excella
Cinnaminson , New Jersey
'99-34' struggling to find a leak by door!
Hello all! Looking for anyone who may have run across this. I have a 99-34' I purchased last winter. I have had a leak by the door and heavy yet to track down the origin. Th dinette keeps getting wet right where it meets the floor and the entrance door. I have been over the roof and components several time looking for this leak. I thought I found it 2 times but still getting wet. I have resorted to covering roof components with plastic to see if it stops. Today I have covered the entire door.
To date I have caulked the seams and redid the caulking for the door brow. I plan to replace the skylight and front fan but they don't seem to be the source as they were covered and still got it. Pics below. The black plastic was my original attempt. The clear is what I put up tonight. Gonna rain tomorrow we'll see. Any thoughts or anyone have a similar experience??Click image for larger version
Name:	ImageUploadedByAirstream Forums1445983264.519643.jpg
ID:	251139Click image for larger version
Name:	ImageUploadedByAirstream Forums1445983307.069421.jpg
ID:	251140Click image for larger version
Name:	ImageUploadedByAirstream Forums1445983330.494438.jpg
ID:	251141Click image for larger version
Name:	ImageUploadedByAirstream Forums1445983350.294815.jpg
ID:	251142Click image for larger version
Name:	ImageUploadedByAirstream Forums1445983369.360381.jpg
excellaf350 is offline   Reply With Quote
Old 10-27-2015, 04:17 PM   #2
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Ours was leaking along the trim at the bottom about floor level. I removed the whole piece from the wheel well to the door and sealed everything. I drilled out old rivets and put new ones in. The trim had been removed before and several rivet holes were left open. A lot of water came in where the top of the trim was not sealed or had pulled away. Doesn't take much.
Good luck,
Joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 10-27-2015, 05:31 PM   #3
2000 30' Excella
Toledo , Ohio
I would be checking around the windows next to your dinette . or the leak could be coming from up above and following down one of the ribs .
woodfox45 is offline   Reply With Quote
Old 10-27-2015, 05:52 PM   #4
1994 34' Excella
Warren , Manitoba
Check the A/C gasket. I had a leak there that ended up just about the same place as you. Also check the rivets or screws holding your awning. You may also have several rivets leaking a small amount each. Capt Tolleys works great on the rivets. Good luck!! Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 10-27-2015, 09:25 PM   #5
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Also check the rail where the awning is attached. That rivet line could need some attention.
PaulnGina is offline   Reply With Quote
Old 10-27-2015, 10:08 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
X2 on awning rail.
CRH is offline   Reply With Quote
Old 10-28-2015, 12:44 AM   #7
1999 34' Excella
Hmmm never thought about behind the moulding down bottom. I did seal the tops so any water will run over I'll have to pull that out and start sealing.
I checked the ac. It's possible but I don't think it's from there. I did seal the windows from the trim to the body but not the trim to the glass. Maybe I can investigate that too.
I've been trying to just find it stopped after I covered something up to narrow it down but seems everything I try hasn't worked. The fabric on the dinette is pretty rough now but if I can find and stop the leak I can live with it for a while.
Old 10-28-2015, 02:25 AM   #8
1988 Argosy 32
Lomita , California
when the rail was added they used standard pop rivet's with no calking under rail and the water runs through the rivet's. nice---Not
Wolfe is offline   Reply With Quote
Old 10-28-2015, 05:08 AM   #9
Kevin245's Avatar
Ditto the awning rail as this is commonly overlooked. I would suggest you look at the antenna base and antenna travel rest bracket too. You may consider rigging up a leak test system if all else fails.
Water traverses the path of least restriction and may be entering the rig far away from the point where we are able to detect moisture inside.
Exterior visual inspection and routine resealing are part of our Spring and Fall maintenance. Any hole or penetration in the skin of an RV is a potential leak source.
Eleanor Roosevelt
Old 10-28-2015, 07:17 AM   #10
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Check where the awning rail ends at the front dome seam. Lots of trailers have the rivet that would be under the rail, missing but the hole is still there. Pry it up a little and you will see the caulking has dried out and there is an open hole.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 10-28-2015, 11:55 AM   #11
2014 27' FB Classic
Cassopolis , Michigan
Check your rivets for a loose or missing one. It only takes one.
biyak269 is offline   Reply With Quote
Old 10-28-2015, 01:57 PM   #12
1987 32' Excella
1999 33' Land Yacht
Clear Lake , Minnesota
In my case it was a cracked lens of the outdoor spot light causing the seeming door leak. Good luck!
Devananda-E9 is offline   Reply With Quote
Old 10-28-2015, 07:20 PM   #13
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
If all else fails, remove the front window stone guards and caulk the entire front wrap-around window frame and particularly caulk the glass against the aluminum frame. Caulk the top side of your running lights leaving a small drain hole on the bottom of the light frame. Check the lens gaskets on the running lights.
NOAZRK2690 is offline   Reply With Quote
Old 10-28-2015, 07:24 PM   #14
2003 31' Classic
Terra Alta , West Virginia
Found mine in the front curbside corner of the skylight. Replaced with a wonderful maxim skylight. The missing rivet front of awning is real under awning rail. By the way I found the skylight leak by some damp insulation. Now I have sealed everything. No leaks. You will find it...really you will.
Dave
wvstreamer is offline   Reply With Quote
Struggling ------ DJBstream Solo Streamers 47 05-21-2014 04:31 PM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
How to find a water leak eddo Fresh Water Systems 9 08-26-2005 02:04 PM
Can Not Find Leak Help! Rennegarbe1 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 05-12-2003 04:08 PM
