Old 03-10-2012, 10:34 AM   #1
2011 28' Flying Cloud
chanhassen , Minnesota
'76 Airstream GT Fixed Window Leak
Seeking suggestions on stemming a window leak.
In Houston where we've had a LOT of rain this season - that's putting it mildly but I know TX needs the rain!
Starboard fixed window beneath operating window has a slow leak in heavy rain. I'm in the process of drying about 6 towels I've used to protect the interior from the moisture!
Taped up outside of window with a cut up black trash bag covering the glass. Water stream has been coming from the inside - just this morning, I took some duct tape and ran the tape from inside the trailer, against the glass and the top of the beauty ring - that seemed to stop the leaking.
I do have a small tube of silicone on hand and can run to Home Depot to get some Vulcum - thinking I'll drill out the rivets, remove the beauty ring and run a bead around the inside edge where glass meets the aluminum.
Open to suggestions before I get to work.
Thank You!
Ken
kentuvman is offline   Reply With Quote
Old 03-10-2012, 04:44 PM   #2
Thank You!
Ken
Removed beauty ring - water looks like coming in from old Vulcum seal on exterior - will see if captain tolley can help!
Thank You,
Ken Tuvman
Old 03-11-2012, 10:17 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Seal both the window to the frame and the frame to the exterior skin. Mask of both areas with black electrical tape as it will stretch around corners. don't forget to seal the split in the window frame. install a nice bead and then remove the tape before the sealant dries. Below is a picture of me sealing the glass to the frame. I did the same after I installed the window.
Old 03-11-2012, 10:26 AM   #4
Aerowood's Avatar
Arvada , Colorado
Here is what it looks like after sealing
Old 03-11-2012, 07:28 PM   #5
I like your suggestion about using black electrical tape - what did you use for sealant and what color? Did you use a caulking gun?
Old 03-11-2012, 08:25 PM   #6
Aerowood's Avatar
Arvada , Colorado
I used an aircraft fuel tank sealant with a pneumatic caulking gun but the same thing can be accomplished with Vulcum or any of the other polyethylene sealants used with a regular caulking gun. Apply a small bead of sealant and then dip your rubber (or latex) gloved finger in mineral spirits and wipe off the excess leaving a nice fillet seal between the taped off areas. I used black sealant but it turned grey after exposure to UV light
My journey to Airstream 'Mothership' THEPILL On The Road... 189 08-02-2017 07:04 PM
Sex in an Airstream Fly at Night Fun & Games 686 05-01-2012 05:44 PM
Need Atlanta-area Airstream renovation expert urban71 General Repair Forum 12 03-10-2012 01:45 PM
2012 Airstream Avenue 20' Lounge with Wardrobe 20' Class B Motorhome eBay Watch Airstreams on eBay 0 03-10-2012 09:00 AM
