Old 05-01-2011, 08:14 AM   #1
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
'72 TW battery/fridge door gaskets
Could someone tell me where I glue the gaskets on the outside doors of
battery and fridge compartments.
This is what I think:
Battery door.. on the inside well (the part that is connected to the camper.. not the door itself) on the 3 sides.. top and left and right side.. not bottom.
Fridge Door.. on the door itself.. all around
Does this sound correct? I am outside working now and need a quick 'ya or nea'...
Thank
Janie Q
Janie Q is offline   Reply With Quote
Old 05-01-2011, 08:17 AM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
You are correct.
Lance
Top is offline   Reply With Quote
Old 05-01-2011, 08:35 AM   #3
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Janie Q,
Where'd you get your gaskets? I bought some gasket material from an Airstream dealer and they were of very poor quality. Was just some adhesive backed foam tape that absorbs water like a sponge.
SilverHoot is offline   Reply With Quote
Old 05-01-2011, 09:13 AM   #4
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
Originally Posted by SilverHoot
Janie Q,
I was told to use the same D gasket that I used one all my windows and front main door. I ordered from Inland RV in California. Be sure to use the 3M black adhesive glue. Not the yellow 3M.
The foam peel and stick for the screen door and roof vents. Did 3M the roof vents but not the screen door.
Janie
Old 05-01-2011, 11:28 AM   #5
Janie Q's Avatar
1972 25' Tradewind
Hammond , Louisiana
Silverhoot,
ARRGHHHH..... just when I thought I had it all correct...
My receipt from Inland RV says I am to use the gasket that is the foam stuff...
All along I have been thinking I'm to use the D gasket..
Crap.. I just removed tons of the old type rubber gaskets.. why would i put on
the foam stuff?
Someone HELP me on this...
Why is nothing easy?
Janie Q
Old 05-01-2011, 05:01 PM   #6
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I used the D shaped gasket. Worked great.
Lance
Old 05-02-2011, 09:42 AM   #7
SilverHoot's Avatar
1967 24' Tradewind
Don't use the foam. Bought it the same place you got yours. It is open cell foam and performs very poorly....
