I have searched but found nothing about the weather stripping for the 70's trailers. It is no longer available from Airstream. This is a special U shape (kind of) with a flat bottom. Any ideas?
Check with Oasis RV they sell it by the foot and will ship it to you.
Good luck!
Hi- I have a '72 that currently has house-hold type foam window gaskets on the windows, and worn-out rubber gasket on the door jamb, NOT the door. I finally had the extra money to get 80' of the 2-fin type original rubber gasket material and want to install it correctly. I'll post 2 pics of how the door gasket was when I got the trailer, and would love for someone to post a close-up pic of how it SHOULD be done on a '72. I'd also love to see a good pic of correct installation on the window- does the short fin glue down to the window frame, butted up against (and also glued)to the right angle of that frame? Thanks for any and all pics, they help me to understand orientations of things. -tim
I think Andy is recommending the "D" profile gasket material for this year of trailer. You can see it on his website.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529 http://northvancouvermodern.blogspot.com/ Live! Life's a banquet and most poor suckers are starving to death! - Mame Dennis
True enough, but I understand that the 2-fin is the original style, works well, and it is what I bought. So- any good pics of correct orientation/installation, both for the windows and the entry door? Thanks- tim
OK- fins out. On the windows, it looks like the gasket fits into the right-angle corner of the frame, but where does it go on the door? It actually seems to work fine where it is, tucked into the corner of the jamb- I'd like to see a good pic from somebody showing it attached to the door. Anybody got a pic of their '72 (or so) door? - tim
I purchased all my weatherstrip from Inland RV and they furnished me with a handy illustration. I hope they do not mind me sharing it. Weatherstrip installation.pdf
Chuck and Vhord- Thanks! The illustration was exactly what I needed to see, I didn't get one from InlandRV like you did. That makes doing the windows completely clear. As far as going on the door, I guess it's supposed to glue right on the very outside edge, even though there appears to be some rivet heads or something kind of in the way in some places? I wonder why it is better to have it mounted here, rather than on the jamb like how I got it- any ideas? I always like to understand WHY procedure "A" is better than procedure "B", just my nature. Now all I have to get is a wire brush for a drill, and/or solvent, and I'm ready to git'er done. Thank you both for the no-nonsense tips on what was quite possibly a dumb question! Also, thanks to Balrgn for his pm's, hope he's having a great Labor Day weekend out in his AS! -tim
Looks like the PO or whomever, when they installed the Dead Bolt, opt'd to put the strip on the door, rather than piece it around the jamb lock and Dead Bolt. Does it work well for you?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC www.balrgn.com www.balrgn.com/Airstream.htm
