Old 09-07-2011, 07:04 AM   #1
1967 26' Overlander
Hoschton , Georgia
'67 Overlander leaky windows, help!!
I have a 67 Overlander that has a few leaky windows. The window to the right of the door is the primary culprit. When it rains, the bottom trays that form the window frame fill up with water. I use parrbond to run a line of sealant across the top of the window where it meets the skin seam. I also have installed new gaskets a couple of years ago. Any suggestions would be appreciated. My big window by the fold out table also leaks a little bit as well.....and it also accumulates water in the bottom tray. Thanks for all your help!!
Sean
mccaa891 is offline   Reply With Quote
Old 09-07-2011, 07:13 AM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Sean
Sean, if your window at the door is the 2 piece, top opens bottom is solid, it leaks where the cross piece at the bottom of the opening window meets the side frame. If you run a small bead there about 1 " front to back it stopped the leak in my 67.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 09-07-2011, 12:46 PM   #3
1967 26' Overlander
Hoschton , Georgia
Thanks so much doug. I assume i should use the parrbond for this? I didnt see a seam of sealant at this location so thats why I assumed it might not be necessary. I will run a bead along the cross section and see what happens. Did your window rails fill up with water also?
Sean
Old 09-08-2011, 07:24 AM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Sean
I got frustrated enough to take the window apart, that's where I found the leak spot in mine. Yes they filled with water.
The front still has a small leak somewhere, I just leave it cracked open and the water runs out.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
1966 Globetrotter
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 09:26 AM
Leaky windows and Star Rivets? gronlampa Windows & Screens 17 10-28-2011 11:09 PM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
