Old 06-15-2009, 10:20 AM   #1
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
'63 Door Gasket
I need to replace the door gasket on my 1963 Tradewind. Vintage Trailer Supply offers one for the period 1957 to 1964, except for 1963. Inland RV offers one, #45313, for the years 1958 to 1963. How can the first one not work for 1963 but the second one will work for the same years including 1963. In a recent posting Andy is quoted as saying that: "For 1963 models, the gasket for the door and screendoor, is the same." But then, in another posting, he says that #45313 is not right for the screendoor and the correct one for that application is #45295. So, does that mean that the correct one for the main door is also #45295, the parts catalog notwithstanding?
Has anyone actually gotten this little job done successfully, and if so, which gasket did you use?
dieseleagle is offline   Reply With Quote
Old 06-15-2009, 10:49 AM   #2
Which gasket/gaskets to use depends on the screen door fit.
If the screen door is flush, with the entrance door, then you use 45295 on it.
If the screen door is not flush with the door, by about 1/2 inch, then you use 45313 on the screen door.
It all depends on which screen door your Airstream has.
In either case, 45313 is correct for the entrance door.
Old 06-15-2009, 11:50 AM   #3
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Thanks for the guidance. I'll double check tonight but I'm pretty sure the door-within-a-door is flush.
Old 06-15-2009, 11:57 AM   #4
1963 24' Tradewind
San Diego , California
My 63 TW screen door is flush and i need both the screen door rubber and the main door rubber, so am i correct to say that the #45295 for the screen door and #45313 for the main door. Andy will that do the trick?
Sixty3TW4US is offline   Reply With Quote
Old 06-15-2009, 11:15 PM   #5
Yes it will.
You will need 15 feet of 45313 and 10 feet of 45295, plus a tube of super weatherstrip adhesive.
Old 06-16-2009, 05:04 AM   #6
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
I checked last night and the screen door is indeed flush. Thanks for the help. I'll be placing my order after while.
Door gasket Sjean Doors & Locks 30 05-09-2017 10:47 PM
Which door does gasket go on? 63air Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-18-2009 12:02 PM
Gasket on door or inside of door? Becky B. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 01:06 PM
door gasket for '96 Excella ~flutterbee~ Doors & Locks 1 09-24-2006 12:11 PM
Leaking door gasket TrailerTramp Doors & Locks 5 05-12-2006 01:24 PM
