Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 01-31-2012, 10:23 AM   #1
2004 16' International CCD
Orem , Utah
6.5hp leaf blower for testing leaks
How can I hookup my my ridgid shop vac leaf blower. I want to hook it up so air enters from outside and pumps pressure into bambi. Then I will need to purchase one hand pumps put some soap and water in there and do inspection.
starcraft is offline   Reply With Quote
Old 01-31-2012, 11:20 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You may not need that much horsepower. The quality of the test will be effected by how well you seal the around where you intend to pump the air into the unit. You may be better able to seal a port going in through one of the exterior compartment doors that an opening as large opening, as the entry door.
1965 Tradewind Table Leaf P&A General Interior Topics 2 09-27-2014 07:49 AM
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
Evaporator blower function Flynavy Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-04-2011 09:04 AM
HELP! kitchen window leaks Jcashcollect Windows & Screens 4 06-23-2011 10:41 AM
