02-27-2011, 08:01 AM
1958 26' Overlander
Mesa
'58 Overlander, Leaks Kicking My butt!
I really need some help. I've got a bad leak under my rear Clearview Window, a bad leak on the streetside front in front of the kitchen counter, a small leak on both sides of the main door, and a bad leak on the curbside front along the front radius.
So far I've sealed the vertical seams and the main awning rail with Parbond, replaced all pop rivets (there were at least a dozen) with Olympic Rivets and Vulkem, and replaced all window seals with new seals.
I'm out of ideas. What else should I look for? Do I need to seal all skin seams whether they're vertical and horizontal? Do I need to remove all drip caps and seal them with Vulkem? The drip caps appear to be fine and I'd hate to remove all the rivets, but if it will solve the leaks I'm all for it. I know the rear 14x14 roof vent leaks (it's attached with screws only and not sealed) and I'll soon be installing a Fantastic Vent Fan to fix that one.
Of all the leaks, the one under the rear window is the one that has me the most stumped. I sealed the window frame with Parbond and replaced the inner and outer window seals, and sealed the black vent stack, but it still leaks bad. Is it possible for the rear roof vent to leak and find itself underneath the rear window? The vent is mounted as far aft as possible in front of the end cap. Most of the water is off center more toward the streetside (the same side as the black vent stack).
The leak in the front radius, curbside is another tough one. The only thing above that are the front horizontal seams. I thought these weren't a source of leaks.
The leak on both sides of the main door is probably the curved brow, so I think I've got that one solved, but the others have me stumped.
Any ideas will be greatly appreciated. I'm at my wits end and need some pointers, especially from those who've worked on the late 50s/early 60s Airstreams.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
02-27-2011, 08:35 AM
1958 26' Overlander
Lander
, Wyoming
Mike, I feel for you man!! Right now I have access to all the inside of the shell so I 'm resealing all my windows as they are being reinstalled. Also I will be resealing all the seams inside and out. I plan to reseal them after the main compound polishing as I believe that makes any prior leaks worse. For example I cleaned off my front endcap with mineral spirits for polishing and looking at the inside could see one leak site . After polishing and cleaning with mineral spirits 3 leak sites were definitely visible!! Wasn't yours was recently polished . Are the leaks now worse? Short of using a dental pick and resealing every exterior seam I don't know what your options are. The rear window leak could be from above, tracks down the rear curved endcap and appears at he the rear window frame. So could be from the vent stack. Any chance the leak is from the dripcap above the window? My rear window and drip cap were originally sealed to the shell with butyl tape. Probably yours as well. Leak at the door could be from the eyebrow but there are also rivets around the door frame. I would also most likely guess its the eyebrow though. Obviously my having access to the inner seams makes my task easy. Figuring out leaks in these things without the interior off has got to be frustrating as the water can track in weird ways. Ed
02-27-2011, 08:48 AM
1959 22' Flying Cloud
Bishop
I am at the same stage on my '59. I too have the interior panels off so sighting the leaks is a little easier. I found that dirt has accumulated over time in every panel seam and that helps hold and distribute the water. One of my front segment seams, which is close to horizontal holds water which then wicks up, sideways and into the interior. Sealing all seams must be the answer.
02-27-2011, 10:02 AM
Nowhere
The worst leaks I found on my trailer when I had all the skins out were related to the window drip caps. I'd focus on those carefully - use a dental pick and solvent to clean it up as best you can, and then go back with Acryl-R or whatever seam sealent you are using. I eventually went over every seam on the trailer and cleaned them up with a dental pick and then resealed. I just assume it is still leaking somewhere. They all leak and the worst leaks are the ones you can't see for one reason or another - at least you know yours is leaking. Keeping them sealed up is an ongoing maintanance issue.
02-27-2011, 11:11 AM
Florissant
, USA
Oy veh Mike.
So many times have I heard there complaints. That brow over the door could be an issue, as could the screws or rivets all along that awning rail.
If I happen to make my way near you or you near San Antonio this summer maybe we can figure them out for you.
Steve
02-27-2011, 12:00 PM
1958 22' Flying Cloud
Folsom
I also have horizontal seams wicking water up then it travels down, sideways, uphill both ways.
I'm following the same process as others, polishing the seams and sealing with parbond. It seems to be eliminating them one at a time. I should note, I even sealed the inside seams with vulkem, but the water is relentless.
02-27-2011, 12:24 PM
Sioux Falls
, South Dakota
I only have experience with this one Airscream trailer. I thought I had one leak between the door and the front of the first front side window. I had 11. I ended up making a religion out of finding those leaks. I was stumped. I removed the inside skin and sat out in the trailer on a farmer's milk stool for a month of thunderstorms with a poacher's light to find them all. The one that eluded me was a middle lap seam. I cleaned the inside and applied a liberal amount of Vulkem as well as sealed the outside again. The hardest to fix was the vista window.
My roof vent leaked on the top and the step release slot leaked at the bottom. Anything between that could leak, did leak. I fixed the roof vent, removed the antenna, and accepted the step release slot was designed to leak.
02-27-2011, 05:11 PM
1963 28' Ambassador
Northern VT
, Vermont
Mike, I did find my rear window leak at the top vent. Water was somehow traveling the inch &1/2 under the center flat sheet by the rear hull bow aft of the vent, between the center endcap laps going around the top of the rear window and dripping of the bottom window sill. Even with the interior stripped including the fiberglass end cap all apeered dry untill the water got to the side of the window frame! It took 3 days to find it. Day 1, let a water hose run slow just above the window all night, nothing..Day 2, same thing just below the top where the end caps meet the flats, nothing... Day 3, let the hose run just forward of the vent, that did it, water dripping from the window sill. Vent flange looked ok, but when removed the sealant was no good. Water had even pulled dirt and grit in between. Resealed, ok. Good luck, these leaks will drive you nuts.
02-27-2011, 05:22 PM
1981 27' Excella II
mays landing
, South Jersey
Im guessin its that rear most roof vent. Good luck. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
02-27-2011, 05:27 PM
Loganville
, Georgia
Mike leaks can travel along the inside top for a long way. When you had your trailer polished did you get it acid washed first. If your air conditioner or vent were installed before it was acid washed then a leak could have occured at those points. The acid might have eaten through sealant or gasket.
My 73 needs to have the airconditioner removed and a new gasket installed. I am pretty sure the air conditioner is where my leak is. It travels all the way to the back of the trailer.
Brian
Brian & Adrienne
02-27-2011, 05:47 PM
1958 26' Overlander
Mesa
Thanks, everyone for the excellent responses. You've all given me excellent ideas. I really appreciate the responses. Yes, I just had the trailer polished, but these leaks were present even before the polishing.
This week I'll be hitting all the seams (horizontal and vertical) with parbond and installing the new Fantastic Vent Fan. I'll also reseal the covered gray roof vent since that is mount on the rear end cap.
The inner skin in the front is off and I took some time to inspect the front for sources of leaks and found that both tear drop running lights were leaking, the curbside front really bad.
1958 Overlander
4CU 1st VP
02-27-2011, 07:23 PM
1965 28' Ambassador
Irving
Mike, the trailer sure looks pretty in the pic.
I had a front window, and side window leak the worst was by the front door.(the five pins holding the Ambassador emblem)
When I stripped down to the shell I found all the leaks.
Things I would look for:The Airstream emblems(when I pulled the old ones it was very corroded under)I also found a major source in two screw holes holding down the air unit.There were a couple of pin holes in the skin also on the side and top.
Good luck.Steve
02-27-2011, 07:53 PM
Sioux Falls
, South Dakota
When I removed my awning roller, I found 5 holes with missing rivets hiding under the roller. I suspect the awning rail was leaking but there were so many other leaks it's hard to tell for sure. I sealed the rivets and the top edge of the rail and all is dry now.
04-26-2011, 08:40 AM
1958 26' Overlander
Mesa
Update
Thought I'd post an update on my leak eradication efforts. It is hoped that somebody out there will find my experience useful in the future.
Well, at the advise of many who replied earlier in this thread, I broke out a couple tubes of Parbond and went to work. Sealing all of the aluminum panel seams eliminated 80% of the leaks but I still had the bad leak on the streetside in front of the kitchen counter and sizable leaks in the bedroom on both sides.
Two weeks ago a bad rain storm hit Phoenix. I decided to take a seat in the Overlander and watch. What I saw was surprising. The source of the leak on the street side front was the Hehr window pictured below. I don't know the name of this type of Hehr window but it doesn't open, the frame is hard riveted to the body. The two windows in the bedroom, which were identical in design as the one in the front, were also leaking, but not as badly. Problem solved. Now it was time to get to work.
The design of these windows is very simple. The main frame that is riveted to the body contains an interior frame that houses the window pane. I was shocked to find that there was no sealant in any of these three windows. No wonder they leaked (the curbside bedroom window did have some butyl tape along the bottom but it was NOT applied where it was needed, between the window and frame). Even though I had replaced the weather seals on these a few months ago with the one available from Vintage Trailer Supply, they really didn't prevent water intrusion. They look nice, to be sure, but as a seal against water they fail miserably.
Since these windows were so old, I decided to fork out the bucks and buy new window panes, especially since I was shocked to find the old front window woefully undersized. The old glass barely reached the top of the window frame. A new, larger piece of glass was obviously needed and would help provide a better seal. Before installing all of the new glass, I sealed them up good and tight with a thick bead of Vulkem. They won't leak now. All of the old, rusty pan nuts and screws were also replaced with the ones offered by VTS.
1958 Overlander
4CU 1st VP
04-26-2011, 09:39 AM
1954 26' Romany Cruiser
Asheville
, NC
Confused
I am glad you have found many of your leaks. I have a '54 Cruiser with all the Hehr windows. I am a little confused/concerned because I haven't witness any leaks with mine and I have barely caulked anything yet, since I am in the middle of polishing. I installed new glass and weather stripping on the outside as you did, and i agree that exterior window seal is probably not a good defense against water. But I didn't believe that it needed to be...
My concern is that I thought that the window drain caps did most of the work in keeping water out. Did you actually vulkem the window pane to the window frame? Inside the keeps? A PO did this to a mangled window, and I found it a rather crude fix. It seems that originally something was working without such a seal.
Please excuse my rambling. After reading this I just assume that all of my windows should be leaking!! I have had the windows wide open in hard rain with no leaks so I am surprised to read about water coming in around the glass.
Yet I have only had my 54 for a few months...guess there are plenty of time for leaks!
04-26-2011, 10:58 AM
1958 26' Overlander
Mesa
Hi Andrew,
I assume the windows that you have in your '54 are the Hehr Standard Windows. It's been my experience that these don't leak or leak very little. Why? The glass in Hehr Standard is mounted in the front assembly which is raised and seals against the backframe gasket. Any water that gets in will simply drip out the bottom since this seal isn't watertight.
The Hehr windows in my '58 that were leaking were NOT Hehr Standard windows. They are a different design entirely, as I explained in my earlier post. The window frames in the windows that were leaking are hard riveted to the body of my Overlander. Any water that gets in will leak inside the trailer. I don't think you have any of these type of Hehr windows in your '54.
The pics show these hard riveted windows. The first is a close up of one of the three I have on my '58. The other pic shows all of the windows on the streetside. The first and third windows are these hard riveted windows, while the others that open are the Hehr Standard windows. They don't leak at all.
1958 Overlander
4CU 1st VP
04-26-2011, 12:00 PM
1973 31' Excella 500
Marysville
Food Coloring for leaks
I used food coloring to help identify the source of leaks. A red drip on the inside meant that water was coming in from where the red was placed on the outside. Blue drops over there meant that water was entering from where the blue was placed. In some cases it took a few days of rain for the color to travel but now I know where my leaks are. Maybe when it stops raining I can fix 'em.
04-26-2011, 12:26 PM
Asheville
, NC
Makes perfect sense
Mike,
That makes perfect sense. I didn't understand the differences between the Hehr riveted directly to the body, and the Hehr standard. I have spent a good while building and rebuilding the standard ones on mine, so when I saw a few pictures of your non-standard I was utterly confused. Your comments confirm my understanding of the water escape in the standard.
You learn something new every day!
04-26-2011, 01:03 PM
1958 26' Overlander
Mesa
Not likely when you live in Washington State.
1958 Overlander
4CU 1st VP
04-26-2011, 02:40 PM
1971 21' Globetrotter
Arvada
I'm starting to win the leak battle. I am striving for a "real leak-less" trailer. All I have done so far is completely take the trailer apart and reseal every seam, window, etc. I shouldn't say reseal because almost every part I've taken apart was lacking any sealant from the start. I don't quite understand why Airstream doesn't assemble wet with sealant. Maybe they are in denial.
