Old 10-26-2015, 06:58 PM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
3M Sealing tape. Trying to find it
Some time ago, here on the Forum, I read about a product made by 3M. If my memory is working it is a polyurethane sealing tape. I recall looking it up and I think it was about 3" wide and available in about a 36" length. (Not sure about this) . I think a product like this just might work to seal roof vents and skylights.
I'm hoping someone out there can help me recall the specific product name and if it is appropriate for rooftop sealing jobs. It was fairly expensive but if it works I will give it a go for my upcoming skylight project.
Thanks all, in advance
Roger in NJ
# 4509
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-26-2015, 07:01 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
It sounds as if you are describing Eternabond. It isn't a 3M product, though.
CRH is offline   Reply With Quote
Old 10-26-2015, 07:03 PM   #3
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I would recommend Eternabond tape
For the application you mentioned, I would recommend Eternabond Alumibond:
EternaBond | AlumiBond / A-Seal, A Seal, Aluminum Faced
I sealed the seams and around all of the roof vents (plumbing and air) on our 34' Avion. I ordered 2 of the 4"x50' rolls, used about one and a half of them to do the entire roof.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 10-27-2015, 06:01 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up 3M.....Extreme Sealing Tape
3M Extreme Sealing Tape .....I've always ordered it from A-zon.
Tech Data
#4412 is the only one I'm familiar with
I did use it for sealing the curb on a new skylight from Inland RV, 5yrs still good as new.
You'll find many uses for it, it has a permanent spot in our traveling tool box.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-27-2015, 11:10 AM   #5
2009 22' Interstate
Chetek , Wisconsin
Try 3M.com
Wisconsinden is offline   Reply With Quote
Old 10-27-2015, 02:47 PM   #6
1968 26' Overlander
Portland , Oregon
3M vhb tape
We use this on our fiberglass sailboats to hold plexiglass/acrylic "windows" on. Very, very strong stuff.
3M™ VHB™ Tape3M™ VHB™ Tape
AirstreamPDX is offline   Reply With Quote
Old 02-06-2016, 05:17 PM   #7
2015 Interstate Ext. Coach
Tega Cay , South Carolina
Can this be used to seal a wood surface? We have a leak in the attic from the frame around the exhaust fan.
Gloria
gghayes is offline   Reply With Quote
Old 02-07-2016, 11:06 AM   #8
Thumbs up
Gloria
I've used 3M Extreme Sealing Tape on most smooth surfaces, more important is CLEAN. Remove all dirt & grease and it will stick.
I did the curb on our replacement skylight 5 Seasons ago....SFSG, no leaks & still
pliable.
PFC
RLC
Old 02-08-2016, 08:42 AM   #9
Ok. Thanks I will try it
Gloria
Old 06-04-2016, 11:38 AM   #10
Iowa City , Iowa
Has anyone compared 3M Extreme Sealing Tape longevity with Eternabond longevity?
Iv read removing EB can be a challenge. Worse then silicone caulk?
Anyway, I want to know which roof tape lasts the longest. And how difficult is the 3M tape to remove?
Thanks!
rebar is offline   Reply With Quote
Old 06-28-2016, 07:38 PM   #11
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
A bit late, but just another "vote" for Eternabond (the 3M may be fine too). I have started cleaning out the old goup around my roof vents then resealing with Sikiflex followed applying Eternabond tape (after the Sikiflex dries). I first used it on the rubber roof on my previous SOB. It promptly put an end to my roof leaks. I think that stuff will last many many years and save constant resealing. I have even purchased some 1" wide stuff that i might apply to the roof seams so can forget worrying about them for a long time. Of course, like any job, prep - a good cleaning - is the key to a lasting job.
Attached is a pic of my rear roof vent with the Eternabond tape applied to the frame edges.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 07-09-2016, 10:47 AM   #12
Warrenton , Virginia
3M user
I was googling 3M Extreme Sealing Tape and came across this discussion. I have used it for 2 years now to seal running lights and damage on my Lance roof. It is holding up real well. It appears that 3M has done a good deal of real world testing on this product for many applications including trailers. It is interesting that not many RV owners have tried it, but it is not cheap. I am getting ready to order more to seal the components on the roof.
12oreo is offline   Reply With Quote
3M Extreme Sealing Tape? cruisette51 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 01-26-2014 08:01 PM
Trying to find Grandpa's Old Airstream...can I find it with Serial Number?? Jakescheid Our Community 13 11-22-2011 11:01 AM
Trying to find a lens cover for a 2007 Bambi gqmmom 2005 and newer - Bambi all models 2 07-11-2010 09:31 AM
Trying to find shower curtain for '93 Excella ghilliedhu1 1990 - 1993 Excella 3 09-05-2009 02:57 AM
Trying to find aluminum caulk Bluto Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 05-28-2009 09:09 PM
