Old 05-04-2014, 12:46 AM   #15
2008 16' International
Seattle , Washington
Picture:
bc_seattle is offline   Reply With Quote
Old 05-04-2014, 04:53 AM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Looking above the fridge vent is that! "L" shaped diverted riveted to the roof. The purpose of this is to direct water away from the fridge vent opening. With the plumbing vent right there it appears the diverter might not be diverting at all and in reality channeling water down the hole instead! On my classic during a decent rain, the amount of water in this area is tremendous! The diverter on mine is way longer therefore moving the water farther from the fridge vent.
I also level mine noss up slightly.
The water finds its way to the back of the trailer via the awning gutters etc.
I would make sure that diverter is longer to get past the vent pipe!
Old 05-04-2014, 07:14 AM   #17
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by bc_seattle View Post
swissdrb - what was your final resolution? Having the same issue tonight in heavy rain in Seattle in our 2008 16'. My guess is the water is coming in the fridge vent (on the side on the 16'). On top of it that side of the trailer is higher than the curb side. (Parked on the street). Will try to level and see if it helps.
prop66 - good suggestion on the level. trying now to see if it will help.
Interestingly didn't happen in heavy rain in same spot a week ago.
Thanks!
BC
That is directly from having the fridge side of the trailer higher than the off-fridge side. I had noticed this effect on many RVs, not just Airstreams. The easiest fix is to make sure that side is the "low side", although you can still get wind-driven rain in the opening.
Old 05-04-2014, 11:42 PM   #18
true-that
overlander63 - you speak the truth (at least on a 16' with the fridge-vent on the side). Leveled the trailer, fridge/street side was high. Rain continued. Leaking stopped. Lesson learned. Thanks!
BC
Old 01-25-2017, 06:28 AM   #19
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
(Reviving an old thread) We camped near the lagoon in Pensacola. Great campground by the way. Big Lagoon SP.
A very nasty and strong storm came in off the water with nearby tornadoes. The trailer was mostly dry inside throughout the night. Then the wind changed direction and the water started pouring out from under the fridge. The vent was the culprit, but not sure why. It has been recently sealed and the cover was replaced and also sealed. Is this just an anomaly or do I need to remove the vent cover and re-seal the vent itself?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
TAC : GA-Stone Mountain Park Rally,April 27-29, 2012 Silverexpress Other Rallies & Events 363 09-12-2012 09:52 AM
WDCU : WDCU Capitol Kickoff Rally - April 26-29, 2012 Skater WBCCI Rallies & Events 40 05-07-2012 07:47 AM
Dogwoods and Bluegrass Rally 2012 63Silver The Rally Zone 123 05-02-2012 06:33 PM
2012 Florida State Rally SilverCabin WBCCI Rallies & Events 109 02-19-2012 06:31 PM
Putting back together,whats this part from batt Awnings 6 02-15-2012 07:07 PM
