Old 09-06-2008, 11:30 AM   #1
1967 26' Overlander
Fairbanks , Alaska
1967 Window Latch adjustment
I read in one of the many theads about sealing windows that you may need to adjust the window latches. I have looked at my latches and wonder if someone can explain the adjustment.
I am also looking for 3 or 4 of the cranks that grab the window clip at the bottom of the window and pull it tightly closed.
Fishbone is offline   Reply With Quote
Old 09-06-2008, 01:56 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Don't know if they are the same as the 70s but those are threaded and have a thin nut that adjusts the tension of the window closer cam.
Old 09-06-2008, 06:04 PM   #3
1967 26' Overlander
Fairbanks , Alaska
Lumatic,
The ones I have are the square box with four screws in it. inside is a brass screw that has a steel cylinder on it. When you crank it it raises off the catch and then you can crank the window open. If I figure out how to use my new camera I will post a pic.
Thanks.
Old 09-06-2008, 06:43 PM   #4
The part that reaches out to grab the window clip, has not been available for almost 20 years.
Molds can be made for $20,000.00 or more.
That part would then have to sell for real big bucks.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-07-2008, 10:50 AM   #5
1967 26' Overlander
Fairbanks , Alaska
Andy,
I'm glad you brought up window clips. The new ones I just got from you have a much thicker slot for glass than the old ones. Are you supposed to pinch them together or are you supposed to fill the gap with something. I'm worried that pinching them will throw them out of shape and they won't latch properly.
I removed an old one and the factory had put some kind of cloth (tape) in the clip or on the window when installed. I'm almost ready to put my windows back in and will need your suggestion on what to do with the clips to do it right.
Thanks!
Old 09-07-2008, 12:53 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Andy,
Thanks!
The tape you see is likely double faced tape and that is what you will need to secure the clips to the glass again. I had no luck using the clips I bought from Inland (your results may vary). Place the tape on the glass first and then slightly spread the correct clip open and position it on the glass over the tape. Then trim any excess tape from the clip edges. I bought new clips from Steve at VintageTrailerSupply.com and you can too! They fit 3 different size glass thicknesses. You can look them up on his website under windows, glass and 66,67,68 curved glass. Hope this helps. Ed
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
BIGED52 is offline   Reply With Quote
Old 09-07-2008, 01:00 PM   #7
Andy,
Thanks!
Our window clips were recently redesigned.
You can add double sided tape, or you can squeeze them together, or both if you wish, your choice.
Our window clips are bright and shiney, not dull like others.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-07-2008, 01:37 PM   #8
window clips.
We have sold over 8000 window clips for the 66-67 and 68 trailers.
Very rarely, did someone have a problem installing them.
Without exception, if that person called us, 10 to 15 seconds of instructions, resolved the matter.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-07-2008, 04:00 PM   #9
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Andy, I did not say that they could not be made to work. I tried buytl tape and squeezing them tighter to fit the Corning glass windows. Which is what I was told by one of your customer service folks, but I was not comfortable with the final fit. So I replaced them with the ones I purchased from VTS. That is all. I simple stated that I was and am happier with the look and fit of the other ones I installed... shiny or not. I have no wish to offend. I was just letting the author of this thread hear one opinion. Sorry if you mis-interpreted my post. Ed
Old 09-07-2008, 11:40 PM   #10
Alumanutz's Avatar
1966 22' Safari
Chico , California
All of the items you need are on Ebay right now. Item number: 220278853524
Let us know if you get them!
NUTZ
Alumanutz is offline   Reply With Quote
Old 09-08-2008, 06:51 PM   #11
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
shhhh Alumanutz, nobody was supposed to see that item, I need a few of the cranks on there etc. geez now its gonna cost me more wow just looked and its already up to 26 bucks
goransons is offline   Reply With Quote
Old 09-08-2008, 06:57 PM   #12
Alumanutz's Avatar
1966 22' Safari
Chico , California
OOPS, Sorry!
Old 09-08-2008, 07:40 PM   #13
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
$41.00 and counting.
You guys need to get together and split the cost..... I've seen these things go for over $30 for one. Makes you wonder why there arn't a bunch from stripped trailers.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
clancy_boy is offline   Reply With Quote
Old 09-08-2008, 07:46 PM   #14
goransons's Avatar
1963 22' Safari
no kidding, I just need the brass screw and the handle for one of the 3 on the bathroom window, and a few of the barrel nuts from Andy, but I'm going to order those new.
Old 09-08-2008, 09:33 PM   #15
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
Andy is correct....they have not been made the latches in years. I need 5... if you find a source for $30.00 each. I may but a lathe and make my own and retire...@ $20,000.00 each.
Take the componets to a machine shop....I'm guessing $50.00 each.
KeithC is offline   Reply With Quote
Old 09-09-2008, 07:16 AM   #16
Silverhobby's Avatar
Greeeneville , Tennessee
Send a message via Yahoo to Silverhobby
Available from Dearly Departed AS Trailers
I think this is the Phillips operator that people are posting about.
Kevin with Baity the Lab/Pointer
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Silverhobby is offline   Reply With Quote
Old 09-12-2008, 09:18 PM   #17
1967 26' Overlander
Fairbanks , Alaska
Thanks for the tip on VTS. I must have got the old clips because they are way too thick for the corning windows. Pinching one together I found it changes the alignment for the catch that pulls it closed and does not pull real tight. Now I own 8 clips that obviously needed to be redesigned.
Old 09-12-2008, 09:20 PM   #18
1967 26' Overlander
Fairbanks , Alaska
If you win the bid let me know I need at least one screw barrel.
Thanks.
Old 09-12-2008, 09:23 PM   #19
1967 26' Overlander
Fairbanks , Alaska
I saw something at the hardware store that got me thinking.... Danger, danger. There are shut off valves for sink faucets that may come fairly close to the brass screw in the latch crank. When I get back from a week of fishing I will post findings.
Old 09-12-2008, 11:18 PM   #20
What you see, is not always what you see.
The brass screw and barrel nut, have what is called a "double start" thread.
That complicates the matter.
I paid, from a friend, $110.00, for one tap.
Andy Rogozinski
Inland RV Center
Corona, CA
Door Latch Adjustment moosetags Doors & Locks 15 04-17-2024 04:32 PM
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
1967 cabinet latch pinktrailer Cabinets, Counter Tops & Furnishings 7 07-18-2007 07:13 AM
front window adjustment jackt Windows & Screens 2 03-18-2004 05:36 AM
Window latch adjustment question! Kistler Windows & Screens 4 08-30-2003 01:10 PM
