Old 07-30-2015, 05:02 PM   #1
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Wiring Fantastic Vent fans
Will a single 12 gauge wire run three vent fans or does each one need it's on power supply. It has one 12 gauge white wire ran to the converter for the grounds. Could not find any pro or cons on this issue. It looks like numerous people have installed multiple vents and I hope someone can help me out. Trying to verify the 12 gauge wiring that was installed in the Airstream is everything I need to complete the 12v system before putting walls back. PO liked 12 gauge wire.
cole3444 is offline   Reply With Quote
Old 07-30-2015, 06:33 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have run 3 on the same circuit for years with no problems. Very seldom are they all on at once though. Your fuses should protect you.
Old 07-30-2015, 07:41 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I think they only draw about 2 amps on the fully revved up setting, 12awg wire should be fine, however you might notice a slight voltage dip if your run is lengthy.
Old 07-30-2015, 08:04 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Should be nonissue to daisy chain 3 FFs on a single 12 AWG circuit, as short runs of that size wire is rated to 20 amps in free air. Don't forget to use a 20A fuse on the circuit positive.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 07-31-2015, 10:01 AM   #5
1971 31' Sovereign
1972 31' Sovereign
Wiring Fantastic Fans
Thanks for all the input and the continued knowledge shared on this site. I thought it would be ok but I wanted a second opinion before I reattach the interior walls. Thanks Jim
Direct Wiring Fantastic Vent Al and Missy Roof Vents, Skylights & Fans 0 09-07-2014 11:21 PM
Need help with fantastic vent wiring oldwoodguy Lights - Interior & Exterior 15 10-02-2012 06:15 PM
Wiring for Fantastic Vent Air Cruiser Roof Vents, Skylights & Fans 6 05-04-2011 03:16 PM
Cleaning Fantastic Vent Fans John S. Roof Vents, Skylights & Fans 11 10-22-2009 07:09 PM
fans or no fans goransons Refrigerators 8 12-31-2007 12:21 PM
