Old 04-22-2009, 10:09 PM   #1
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Why does the fan / vent pop open during travel?
I thought i saw this post once before. I cant find the solution to this phenomenon. After a few hours of towing I find that the bathroom fan / vent has popped up? I pull it down as t seems like it has plenty of spring pressure against it and once again i find it popped up .
Whats the deal? I hope i dont hear about running gear... I had all that done. Anyone ??
Thanks Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 04-23-2009, 12:48 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Wild guess?
Hi, maybe if you tow your trailer with an open window and the pressure builds up, pop goes the bathroom vent.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-23-2009, 04:48 AM   #3
redstart's Avatar
1998 34' Limited
ont , Ontario
that was me!
maybe you saw my posting?
http://www.airforums.com/forums/f455...tow-41588.html
we had to replace a 17$ part in the fan and it hasn't happened again. 2airishuman provided the info i needed (miss his posts!).
redstart is offline   Reply With Quote
Old 04-23-2009, 08:07 AM   #4
moderator
Airslide's Avatar
Wilton , California
Images: 50
Hello Robert,
Thats something i didnt think of.. pressure in the fusalage.. Hmm.
The fan that im speaking of is a small round one. The handle pushes up the whole outside cover. I dont think it should be a problem if its open while traveling but strange that it happens.
Vinnie
Old 04-23-2009, 08:42 AM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
I don't recommend towing with any windows open..Period
All too often, owners have lost a window for that very reason..
Why the bathroom vent pops open, is extremely odd.
I'd try a manual latch of sorts to prevent it.
Good luck~!
Be sure to follow up a report on what the final cause and, cure is.
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 04-23-2009, 09:07 AM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
It may be as simple as forgetting to close the stove vent. Any air pressure that builds up inside will have to vent somewhere and the bathroom vent IS cheaper than breaking out a window because of air pressure. Also make sure your fantastic fan(s) are OFF when you tow - speed 0 and lid down - if they are just closed due to the rain sensors detecting moisture, they could open during transport and start sucking air into the coach.
Paula
Old 04-23-2009, 10:01 AM   #7
Thanks Vinnie
Try some Centramatic balancers.
The wind current has nothing to do with that cover opening.
Since it only opens in transit, then vibration can be the only cause.
Old 04-23-2009, 03:08 PM   #8
moderator
Airslide's Avatar
Wilton , California
Images: 50
Hmmm.. I thought you might say that..
Thanks Andy.
Old 04-23-2009, 03:17 PM   #9
Thanks Andy.
Please remember, that moment arm increases with distance.
What ever vibration may be at the wheels, it increase the further rearward you become from those wheels.
I didn't say it, by try riding in the area of the vent at 50 or 60 mph.
It could be enlightening for you.
Old 04-23-2009, 05:37 PM   #10
moderator
Airslide's Avatar
Wilton , California
Images: 50
Funny you should say that. I had my son who is 20 ride in the trailer down the freeway (i know its not legal but just wanted to know) He was green by the way once out.. He said he put a glass of water open on the table and it didnt even spill.. no vibration.. felt like you were flying in an airplane. He didnt like the curves however once in the neighborhood.
Old 04-28-2009, 06:15 AM   #11
redstart's Avatar
1998 34' Limited
ont , Ontario
well, i wondered what it would be like inside the trailer when towing - now i know!
are you sure the fan gear isn't warped? i know i'm not saying it properly but the teeth in our fan didn't align and, even though the fan closed properly, it would pop up when towing or in a strong wind. An easy fix - apparently from over tightening it when closing.
Old 04-28-2009, 08:55 AM   #12
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Riding in a travel trailer is not illegal in all states, so your son can enjoy many hours of watching that glass of water in the right (or wrong) places.
Gene
Old 04-28-2009, 09:06 AM   #13
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I rode in the trailer right before we switched the factory unbalanced running gear for a balanced disc brake set up.
Before, I needed a seat belt. Not only did it bounce me around. The trailer made a whole lot of unpleasant noises.
After, Nice smooth ride and a lot less noise.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 04-28-2009, 09:22 AM   #14
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Where did you get the disks balanced?
I'll have to admit that I was appalled when I learned about the need to static balance the wheel/brake assembly. (Thanks Andy, I can see the evidence of out of balance running gear in my Trade Wind, but that was prior the the Internet, much less the forum. I know what to look out for now.)
If all the auto makers in the world can balance their brake/hubs, why can't trailer axle makers? They are certainly not bargain priced.
Vaughan
1950s fan travel trailer farmgirl Vintage Kin 12 11-21-2010 04:05 PM
vent fan Judy Barde Roof Vents, Skylights & Fans 2 06-02-2008 09:06 PM
bathroom fan pops open when we tow! redstart Roof Vents, Skylights & Fans 11 05-07-2008 10:14 AM
Sure Line Vent Fan Chaplain Kent Roof Vents, Skylights & Fans 1 03-31-2006 09:07 PM
Bathroom fan vent? dustyrhodes Roof Vents, Skylights & Fans 2 12-01-2005 08:17 PM
