Old 06-26-2011, 11:41 AM   #1
bennyg's Avatar
1973 23' Safari
New Albany , Indiana
Why does 1 of my 3 vents look different from inside?
I have a 73 safari and one of my three vents have a plastic mold and 2 rails riveted across. just curious why? also I plan on putting in a fantastic and would appreciate if someone had any recommendations as to which one of the three i should put the new vent in.
Thanks, Ben
ID:	133343   Click image for larger version
bennyg is offline   Reply With Quote
Old 06-26-2011, 11:55 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
On mine the rails support the factory fan. I would pull that one apart and see if there is 12 volts tucked in there somewhere
2004 Excursion 4x4
Old 06-26-2011, 01:10 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
My trailer had power vents at the front and bedroom locations. The middle vent had no fan. I removed them all and replaced all three with FanTastic fans.
Old 06-26-2011, 01:22 PM   #4
Spring Hill , Florida
Ah ha! That explains why the middle Fantastic Fan in my Sovereign keeps blowing a fuse every time I move the trailer. Whoever put in the wire screwed up.
sepezlover is offline   Reply With Quote
Old 06-26-2011, 02:44 PM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yes, I still have the fan in mine. works good...kinda loud, though. one day, I'll replace it w/ a Fantastic.
you should be able to find a wire for a light fixture, as well as a fan.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Screen inside fridge vent cutterbug Exterior Storage Compartments & Access Doors 3 07-19-2011 08:08 PM
inside latch/lock for '78 Argosy Minuet ArgosyMinuet All Argosy Trailers 1 06-20-2011 05:03 PM
Dust accumulation inside AC... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-06-2011 05:32 AM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
