Old 03-01-2016, 01:08 AM   #15
Kreimer's Avatar
1965 22' Safari
1987 34.5' Airstream 345
Kansas city , Missouri
Name:	ImageUploadedByAirstream Forums1456819530.026524.jpg
ID:	258017Click image for larger version
Name:	ImageUploadedByAirstream Forums1456819552.621764.jpg
ID:	258018. I just installed the maxxair deluxe on our 345. Very happy with it so far! We also have a basic fantastic fan on our '65 Safari. It is adequate. Not fancy but does the job
Kreimer is offline   Reply With Quote
Old 03-01-2016, 09:30 AM   #16
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The Fantastic Fan branded rain shield takes up space and shadows any solar panels beside it even if the fan itself is not in use. The MaxxFan is closed when not in use. And not doing any shading of the adjacent solar panels.
Old 03-02-2016, 06:49 PM   #17
Viggen's Avatar
2016 19' Flying Cloud
Davidson , North Carolina
Tinbender, which of your trailers did you have the issue with the Maxxfan? I have a Sport 16 and thinking of installing one.
Viggen is offline   Reply With Quote
Old 03-03-2016, 05:36 AM   #18
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Viggen, my Bambi is a 16'. The tv antenna is mounted behind the fan so that is where the clearance issue came in for me. Your situation may be different depending on how things are arranged on your roof.
Surely not gonna make new holes in the roof to relocate antenna. Ordered a remote controlled Fantastic, problem solved 😄😄
'01 16' Bambi --- Swee' Pea
'13 23D International --- Trixy
'09 Silverado --- Big Bertha
Adoptee -- '78 Argosy 24' Moho -- Big Girl
tinbender is offline   Reply With Quote
Old 03-04-2016, 04:54 AM   #19
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Good point, to consider for some Switz though my panel config is not hindered. I still am set up to gather rays from the sides of the trailer rather than the ends and the way that my roof config is, the vent and cover are not in the way. Still, for someone else, that may be a concern. It is like a decision between less obstruction or better air flow. Depending on the application, one or the other may not matter.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 04-02-2016, 06:12 AM   #20
1999 34' Excella
Cinnaminson , New Jersey
I've owned both. Installed maxxfan deluxe 5100's in my old trailer. Loved them. Left them open all the time. We could leave the trailer for the day out sight seeing ect and no worries.
New to me trailer has 1 fantastic with rain sensor in it. It works ok but as stated its finicky. I'm not a fan of the fantastic. It's installed in the bedroom over the bed. I hate it. I have to climb across the bed to reach it. Just ordered a maxxfan 7000 with a remote to replace it.
Since I already own it im thinking of putting it in the bathroom cause that vent is broken. I will put a cover over it cause I don't trust the rain sensor.
excellaf350 is offline   Reply With Quote
Old 05-22-2016, 07:55 PM   #21
1972 27' Overlander
Thank you to all. Great info.
t
sir_tob is offline   Reply With Quote
Old 12-04-2017, 05:01 PM   #22
2016 30' International
redondo beach , California
We put a switch in series with the rain sensor on the Fantastic Fan.
Now we can turn the sensor on and off.
ID:	300327   Click image for larger version
Randy and Beth
2015 F250 Titan 50 gallon tank
2016 International ProPride, EasyStart, Michelin 16", Battle Born LiFePO4 x 2, PD 60 Amp converters x 2, Victron BMV 712, Orion 12/12, and Blue Solar MPPT all in a rolling experiment
Nobody's perfect and I'm a perfect example
mythbuster88 is offline   Reply With Quote
Old 12-05-2017, 07:44 AM   #23
switz's Avatar
2014 31' Classic
Images: 8
We replaced the stock Fantastic fans on both trailers with MaxxFan 7000K series and never looked back. That also got rid of the ugly "rain cover" for the Fantastic fan on the Classic.
The reversible and ten speed fans are wonderful and the rain protection when open is built into the lid that opens when running.
Old 12-05-2017, 11:05 PM   #24
And today I put in a DPDT switch to reverse the fan motor. Now the fan is even more fantastic.
Randy and Beth
Old 12-05-2017, 11:06 PM   #25
Very hard to keep up with the SWITZ!
Randy and Beth
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Fantastic Fans: Which Model to Buy??!! JimGolden Electrical - Systems, Generators, Batteries & Solar 77 08-14-2012 08:17 PM
Fantastic ventrights - which model? Dureedesign Roof Vents, Skylights & Fans 7 06-05-2012 08:19 AM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
