Old 09-04-2010, 03:43 AM   #1
Madison , Wisconsin
Where do I get power for my fan?
My wife and I recently bought a 2006 25' Safari FB and want to put either a fantastic fan or maxx fan above our bed. Unfortunately the old vent is not prewired. I saw on one thread about getting power from the bathroom vent fan.
Is it possible to get power from the LED lights in the ceiling? They are much closer and would be easier to access. Would that circuit be able to handle the fan?
Any help would be greatly appreciated.
Jimmy
Mfdfyr is offline   Reply With Quote
Old 09-04-2010, 07:21 AM   #2
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Jim,
I just installed 2 Fantastic fans in my 1985 Sovereign. I installed them in the 14X14 vent openings in the bedroom and living room areas.
It was very easy to snake a wire to the light fixture circuit but I did have to drill a small hole in the cross member for the wire. Piece of cake. Circuit will handle the Fan and light, I am told.
Good luck,
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 09-04-2010, 07:26 AM   #3
Dan@LED4RV's Avatar
Denton , North Carolina
power from lights
Jimmy
Jimmy,
Pulling a wire from the lights that are close is your best shot. When I use to work in service, we did that all the time and never had any problems from it. Airstream designs the circuit with room to grow.
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 09-04-2010, 07:39 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by airdreamers View Post
Jim,
If you drill add a rubber grommet to the hole or otherwise prevent the wires from have the insulation cut.
You might also find a dip in the rib, between the rib and skin a little ways one way or the other down the rib you can fish the wire through
Old 09-04-2010, 08:50 AM   #5
aftermath's Avatar
Spokane , Washington
Jimmy,
I have a 2006 FB SE and about two weeks ago I had it in the shop. I asked the tech about installing a fantastic fan in the bedroom, specifically wondering about wiring in the ceiling. He told me that, yes they were wired and installing a fan was a rather easy thing to do.
Do you know for sure that there is no wiring in your unit? I do remember reading that pulling electricity from a ceiling light would require your lights to be on whenever you wanted to run your fan. I have not looked at a schematic but I would think that the hot lead goes to the switch and not to one of the lights in the ceiling.
Dick
aftermath is offline   Reply With Quote
Vent fan power? 1963 RichardT 1961 - 1963 Bambi 1 10-16-2014 04:14 AM
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
Power to roof vent fan modarch Electrical - Systems, Generators, Batteries & Solar 0 11-29-2008 06:04 PM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 07:44 PM
