08-01-2019, 03:21 PM
2018 27' Globetrotter
Vancouver Island
, British Columbia
What sealant to use for that
I thought I did such a good in sealing the roof. After two days of rain I noticed a small leak inside and it looks like there is caulking/ sealant missing on the outside windows ( not the window frame).
Can anyone tell me what I should use to replace the missing calking / sealant .?Please sea photo
08-01-2019, 04:37 PM
2000 25' Safari
Denver
, North Carolina
I took this from another post.
SEALANTS: SUMMARY :
NO SILICONE:
For wheel wells/underbody:
Vulkem 116
Trempro 635 Grey
Sikaflex 221 Black (use Eternabond spray cleaner to prepare surface)
Adseal Premium Quality Sealant Grey
Roof:
Sikaflex 221 White (for roof seams, seals and bonds. Use Eternabond spray cleaner to prepare surface)
Sikaflex 715 (around fans, vents, skylights ... self-levelling)
Adseal Premium Quality Sealant White
Dicor self-levelling sealant
EternaBond® AlumiBond (alum. backed sealing tape, 2", 3", 4", and 6" wide)
Lexel™ Clear
Windows/Trim/Rubrail/Exterior Lights:
Sikaflex 221 Grey (seals and bonds. Use Eternabond spray cleaner to prepare surface)
Parbond Grey or Clear (small hand tubes, prep and clean-up use cosmoline remover)
Trempro 635 Grey
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Lexel™ Clear
Small seams (between aluminum panels):
Acryl-R (available in cans from Airstream store. Use applicator or disposable syringes to apply)
Aluminum Pigmented Gutterseal
Rivet sealer:
Captain Tolley's Creeping Crack Cure
Parbond Gray or Clear (small hand tubes), also good for small gaps (<1/8”) such as top of belt line rub rail, door/window frames, etc
08-01-2019, 04:51 PM
Vancouver Island
, British Columbia
SEALANTS: SUMMARY :
NO SILICONE:
Vulkem 116
Trempro 635 Grey
Roof:
EternaBond[emoji768] AlumiBond (alum. backed sealing tape, 2", 3", 4", and 6" wide)
Lexel[emoji769] Clear
Trempro 635 Grey
Loctite[emoji768] PL[emoji768] S40 Polyurethane Window Door and Siding Sealant
Rivet sealer:
So from my picture would you use tempro for the glass seal ?
08-01-2019, 05:01 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Captain Tolley’s
08-02-2019, 01:30 PM
1999 28' Excella
Lake Mary
Sealant
I have my best luck with marine products. Use Life-Calk for roof top units, their sealant stays flexible. For small holes and screws, you can also use RTV gasket/sealant.
08-02-2019, 01:39 PM
Vancouver Island
, British Columbia
Thanks I actually looking at those. The distributors that I bought the trailer from are telling me to use silicone. I sent a message to airstream to see what they would do.
08-02-2019, 01:43 PM
Sag Harbor
, New York
I thought silicone was not good for the aluminum skin on Airstreams, because it usually contains acetic acid?
http://www.airforums.com/forums/f456...num-83291.html
"no silicon caulk" search results: https://www.google.com/search?q=no+s...=airforums.com
[click on orange arrow in quote to go directly to this post]
Silicone sealers were used by Airstream many years ago on the exterior.
It FAILED horribly.
You can use it on the inside ot the trailer, but NEVER EVER on the exterior.
For the exterior use Vulkem, Sikoflex and/or Par Bond.
The Vulkem sealer that Airstream used on trailers almost 50 years old (young) is still in great shape.
Vulkem will out last silicone everyday of the week, month, year, decades.
08-02-2019, 01:47 PM
Sag Harbor
, New York
SEALANTS: SUMMARY :
NO SILICONE:
Could you please provide a link to that post?
Peter
08-02-2019, 05:57 PM
Vancouver Island
, British Columbia
Peter
Well according to airstream you use adseal which is silicone .
08-03-2019, 02:08 AM
Sag Harbor
, New York
Perhaps Adseal does not contain acetic acid? See earlier posts.
Good luck,
Peter
