Old 06-25-2005, 06:43 PM   #1
What Is this vent?
Guys,
What is this vent for?
It does not open when I activate the stove fan.
Tom
Stagehand is offline   Reply With Quote
Old 06-25-2005, 06:50 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
More info, pls.
What's on the other side of the vent?
What year and model trailer?
Uwe
www.area63productions.com
Old 06-25-2005, 07:29 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Stove vent, 70's vintage should be opening when you turn the fan on perhaps it is stuck shut? Here is a partial scan of the stove hood assembly. I will take a look at mine when I get home and see if there is any addtional mechanism involved...
WBCCI #XXXX AIR #2495
Old 06-25-2005, 08:06 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's a two-part process. You open the vent, there is a lever inside the overhead cabinet, and then twist a round switch to turn on the fan.
Old 06-25-2005, 09:07 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Terry,
My 75 is a one step process...you pull the lever in the cabinet and the vent opens and the fan turns on...some kind of mirco switch...similar to what it in the overhead vent in the front that isn't there anymore If Tom will chime in with the specfic year and model we can help him out a bit more.
Aaron
Old 06-25-2005, 09:28 PM   #6
Well Preserved
1993 21' Sovereign
Originally Posted by wahoonc
Terry,
Aaron
My '72 had the one-step lever/switch, but the '75 has a lever inside the cabinet, that you move left, and push up, then a round switch similar to the overhead light switch that you twist to turn on the fan. A year would be a great help in determining which way it is supposed to work.
Old 06-26-2005, 08:35 AM   #7
Guys,
It is a 1976 25 foot Int. with an "island" type setup.
One step lever, pull down on the control panal mounted above the control panel.
I didn't hang around for the reply.
Tom
Old 06-26-2005, 08:39 AM   #8
That .PDF explains it.
You can take the rest of the day off with pay.
Thanks again,
Tom
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
Roof Vent Covers Dwight Roof Vents, Skylights & Fans 2 10-13-2003 10:16 AM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 07:44 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 04:23 PM
