Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 08-03-2009, 04:58 PM   #1
Profile:  2007 27' Classic FB
Todd , North Carolina
Weird Discoloration
The plasic cowling and trim of my ceiling vent fan broke out with an ugly brown "rash" two years from date of manufacture (2007). Assuming that it was rust over metal (silly me) I pulled the offending parts (had to cut 4 wires) and took the offending parts to my shop for re-painting. When I discovered I was dealing with plastic, I turned to 320 grit sandpaper. I eventually removed the brown stuff to a satisfactory level. The offending gunk seems to be a clear overspray applied during manufacture that discolored after 2 years.
Has anyone else out there run into a similar situation and is there an easier way to treat the situation?
evsjr is offline   Reply With Quote
Old 08-03-2009, 07:46 PM   #2
Triple M's Avatar
Profile:  2005 19' International CCD
Upton , Massachusetts
I have the same problem. I haven’t done anything about it yet. But if the sanding worked I will try that.
Mike
Triple M is offline   Reply With Quote
Old 08-03-2009, 09:09 PM   #3
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
I have the same problem. Nothing seems to clean it off. I have not tried mechanical means yet.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 08-03-2009, 09:51 PM   #4
Halimer
Profile:  2006 25' Classic
New Hyde Park , New York
It is overspray of the glue to hold the insulation in place by the factory. Give Fantastic Fan a call they can explain it. I had my trim replaced and inner panel with electronics upgraded to get an in/out fan switch at Madison by Fantastic Fan. Some cost on my part.
Mark
halimer is offline   Reply With Quote
Really Weird Bedspread SRW Upholstery, Blinds, Walls & Interior Finishes 11 06-24-2009 09:12 AM
discoloration of exterior aluminum funkill Clearcoat, Exterior Paint & Trim 0 06-03-2009 10:58 AM
Weird Sway setup flyingscot Towing, Tow Vehicles & Hitches 19 10-01-2007 09:28 AM
something weird when I hook up to the car? 59er Lights - Interior & Exterior 8 08-06-2007 12:29 PM
weird!!! rebel beck Plumbing - Systems & Fixtures 8 06-29-2006 10:06 AM
