Old 12-13-2009, 10:29 AM   #1
1965 17' Caravel
langley , British Columbia
Weight on roof
I have to fix the fan and skylight on my caravel....i was going to put a padded ladder against the wall,,,but being 230lbs. I`m a bit concerned of denting the wall,,,,and once on the roof how how strong is it,,,if i move towards the middle isn`t there a big chance of denting the roof,,,,,,,,,,,,thanks keith
trout-fly is offline   Reply With Quote
Old 12-13-2009, 11:09 AM   #2
1971 29' Ambassador
Leonardtown , Maryland
Get a ladder tall enough to rest against the awning.
Cut 2 or 3 pieces of ply wood about 2 to 3 sqft and use them on the roof to distribute your weight.
This system works on my classic and I am 260 lbs.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 12-13-2009, 11:57 AM   #3
You can walk, "notrun or jump" on the roof.
Just don't go forward or rearward of the awning rail.
Our shop foreman weighs 260. How doesn't cause any roof damage.
All you need to do is wear rubber soled shoes, and stay off the roof if it is damp or wet. Other than that, you won't hurt a thing.
The fabrication of gadgets, gimmicks and equipment that some owners use, to get on the roof, is totally unnecessary.
Place a padded ladder against the drip cap of a side window, and simply get up on the roof.
After 43 plus years, I have yet to see any roof damaged by someone walking on them. And, I see many many roofs.
Old 12-13-2009, 11:59 AM   #4
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Look for the rivet lines and try to keep your plywood covering 2 at a time. Dave
easyride is offline   Reply With Quote
Old 12-13-2009, 12:00 PM   #5
1965 17' Caravel
thanks rebee,,,,,,,,i don`t have an awning,,,,but the plywood is a good idea..........thanks keith
Old 12-13-2009, 01:41 PM   #6
1965 17' Caravel
Thanks andy,,,you are a great help,,this is what makes this site so good,,there are so many people willing to help,,,,,,,thanks ,,,,,keith
Old 12-13-2009, 02:25 PM   #7
Kevin245's Avatar
Keith,
With a straight ladder it's a good idea to pad the areas that contact the shell. I've also seen people strap a padded 2"x 4" across the face of the ladder where it makes contact with the shell to help distribute the load.
We walk the rib lines when moving around on the roof. Since most of my work involves working from the knees I use some padded 16"-ish squares of 1/4" masonite for knee boards. The padding is for my knees and it also helps keep tools, fasteners and such from sliding around
Just make sure you stay off the end caps and take your time.
Regards,
Kevin
Eleanor Roosevelt
Total Weight & Tongue weight of 24' Argosy woody_strohm Our Community 3 12-21-2008 10:25 PM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
