Old 11-14-2015, 03:32 PM   #1
1959newbie's Avatar
Hill Country , Texas
Vintage Trailer Supply Astradome-earlier problem
My Astradome assembly is completely original and functional, including the Ladeau (how it's spelled on mine) lifters. However, the PO's replacement cover blew off on my last camping trip, after 9 years of just sitting there quietly.
Because I had immediately installed Fantastic vents in my two square vent openings, I never used the Astradome for anything but the light it let in, so never inspected it that closely -- i.e., never paid much attention to how lifters were attached to the now-gone plastic cover. But I DO know they were capable of raising it up and down, because I checked in 2006 when I acquired this 1959 Overlander.
I just received the VTS replacement cover this week, and it certainly fits over my oblong opening fine. However, no instructions or diagrams came with it, and the scant instructions under its listing on VTS website are no help.
Before I drill holes in this incredibly expensive piece of plastic, I want to be sure I'm putting them in the right places!
Name:	ImageUploadedByAirstream Forums1447539132.684379.jpg
ID:	252049Click image for larger version
Name:	ImageUploadedByAirstream Forums1447539156.650360.jpg
First pic is closeup of one lifter.
Second pic is screen with lifters attached, in front of new VTS cover.
It seems that if the cylindrical lifter bodies are to be perpendicular to both screen and cover, the triangular metal pieces will have to be screwed into the wide horizontal rim of the cover. But if they are, the hinge pins will prevent the hole-end of the triangular metal pieces from resting flush against the part of the cover to which they are attached.
If I were to move the hinge pins inward to the inner edge of horizontal rim of cover, the lifters would have to both lean inward quite a bit.
Does anyone understand my question? Or have a solution? Do I need to send this VTS cover back and try the Inland one? Or something else?
We're going camping next weekend, had no idea this would be a major headache, as all I was missing was the plastic! No response yet from VTS.
Help!
Lynne
1959newbie is offline   Reply With Quote
Old 11-14-2015, 04:55 PM   #2
65CV's Avatar
Western , Massachusetts
Originally Posted by 1959newbie View Post
...It seems that if the cylindrical lifter bodies are to be perpendicular to both screen and cover, the triangular metal pieces will have to be screwed into the wide horizontal rim of the cover. But if they are, the hinge pins will prevent the hole-end of the triangular metal pieces from resting flush against the part of the cover to which they are attached....
Not if you use the right size flat head screw. It's not perfectly flat, but it works. See this blog post for detailed pics.
65CV is offline   Reply With Quote
Old 11-14-2015, 11:15 PM   #3
1959newbie's Avatar
Thanks! The triagular pieces were not folded over before, but will check tomorrow to see if this arrangement will work. May take some effort to get them to fold at this point! One of those pics really helped!
Lynne
Astradome problem micaso Roof Vents, Skylights & Fans 3 09-14-2015 06:34 AM
Flying Cloud 20 2012 or earlier OTRA15 Airstream Classifieds 0 08-16-2015 03:25 PM
Replacement taillights for mid-60s and earlier overlander63 Lights - Interior & Exterior 1 02-27-2011 10:49 AM
1981 and earlier rear suspension deano Airstream Motorhome Forums 15 10-16-2003 12:54 PM
