Old 09-22-2006, 08:38 AM   #1
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
Vents
Hope this has not been posted before but if it has here it goes again. After searching info on new roof vents and the cost of some new roof vents I'm in a crisis of what to do. Our middle vent has started a leak not surprised as the plastic or plexi on the top is cracked as a quick fix last spring I just sealed it. Now the leak is back. I love the way the old ones look because they match. Can you get just the replacement for the top, or has someone on here renovated the old ones. The fans have not worked for sometime, but I do like the lights. Any help on making my mind up and saving the pocket book would be appreciated.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 09-22-2006, 09:52 AM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
Replacement vents for 70's are pretty readily available. Anyone who takes one out to put in a Fantastic Fan has them. There were several available at the RMVAC Swap Meet in August...they couldn't give them away!
I would suggest putting a "Wanted Ad" in the Forums classifieds or keep your eyes peeled on ebay. One will turn up...see if you can temporarily reseal the leak until then. You may also post a "Wanted Ad" on the VAC Classifieds website.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-22-2006, 01:35 PM   #3
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
I ordered replacement "lids" from Inland RV on 3/12/04. I didn't find their cost to be all that prohibitive at that time. You might want to consider replacing with new rather that old since old will likely just have to be replaced again in a very few years.
GStephens
GStephens is offline   Reply With Quote
Old 09-22-2006, 07:17 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You can buy plexiglas at any home store and cut out a piece and glue it in the aluminum frame with vulcem or other urethane caulking compound. Less than $5 repair.
Old 09-22-2006, 07:44 PM   #5
steelbird312's Avatar
2013 31' Classic
Crossville , Tennessee
Images: 11
Becky, If you have the opporunity, why not post a pic of what you have. That way, maybe someone will have what you need or can post a good idea of a fix. I have two older models left that will be going on Ebay in a couple of weeks. One of them might be what you need. In any case, the fan motors on either one are in very good condition, and would do you a good job.....BUT, before you go putting in a different one, I HIGHLY recommend one of the before mentioned repairs. In fact, during the late eighties, and early 90's, the meal top had a square hole approx. 12x12 in it, that had a peice of white plastic riveted and glued on with a sealer. If that is what you have, it not only would be cost effective, but a quick, "best" fix to go that way.
The motors can be replaced very easily, just hold your breath while you pay for it!
Good luck.
steelbird312 WBCCI #6673 jerry Hodge
2013 31" Classic limited
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand, throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 09-24-2006, 08:17 AM   #6
rebel beck's Avatar
1975 31' Sovereign
Images: 35
Just what the doctor ordered, I now plan to repair to old ones. I like to be as original and cost affective as possible. We never use the fans, I do raise the vents for fresh air, but I also love the a/c when it is needed. Thanks for all the advice and I will post pics as we finish.
Becky
Air# 9552
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
Replacing roof vents JAD Roof Vents, Skylights & Fans 10 04-15-2004 09:37 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 02:18 PM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
Does anyone know #16019? Pahaska Our Community 15 06-30-2002 04:25 PM
