Old 07-31-2015, 10:51 AM   #1
2011 30' Flying Cloud
Greenback , Tennessee
Ventline Exhaust Fan Doesn't Work
My Ventline VP-543 power vent does't work; this in a little-used 2011 FC. I am thinking all it needs is a motor (about $11.00, including shipping. The motor I found is Heng's (90037-c1). Does anyone have any experience with this motor? Can I replace the motor from the inside, without removing the exterior parts?
Richard
Gneiss Guy is offline   Reply With Quote
Old 08-05-2015, 07:10 PM   #2
Jim & Mitzi's Avatar
1990 34' Excella
1990 29' Land Yacht
Americus , Also Valrico, Fl
6" ventline moter replacement
Richard
Just replaced motor and blower wheel on our '90 34' Excella. Need to go in from in and out. Not a major project. Wiring easiest from below and the 2 screws the attach the motor are very small & accessible from the outside. 2 screws attach the round cover to the assembly. I was able to remove them the a proper size socket . My new motor has the "D" shaft and the blower wheel did not have the "D" hole. Just slightly enlarged the hole and carefully tapped the wheel on the installed motor with my wife supporting the motor from below. Total time .....less than 1 hour including a good clean up. Be cautious. If side bath a dropped screw could go down the shower drain.
Jim & Mitzi is offline   Reply With Quote
HOW TO: Install a Ventline Exhaust Fan BoldAdventure Roof Vents, Skylights & Fans 2 06-02-2015 08:05 PM
Ventline / Vanair VP-543 bath fan parts jm2 Roof Vents, Skylights & Fans 0 08-25-2010 01:41 PM
Replacement Cap for Ventline Bath Fan SSChanger General Appliance Topics 2 08-15-2010 02:25 PM
Ventline Vanair bathroom fan replacement davidz71 Roof Vents, Skylights & Fans 8 08-29-2009 04:15 PM
Ventline 6.25 inch exhaust fan Darrell Root Roof Vents, Skylights & Fans 2 07-14-2006 06:07 AM
