Greetings Bob!
I haven't had any particular problems with my Minuet and the stock open drain vents; but on my Overlander the previous owner modified the vent stacks in an effort to reduce the amount of water forced out of the traps and into the sinks and bathtub when traveling. In the photo below, if you look at the roof, you'll note that the white PVC pipes at the drain vents have a 90 degree bend and point to the rear:
My Minuet has been stored outside in the Midwest all of its life - - its previous owner lived in Southern Indiana - - and there is no indication of problems resulting from the "open" drain vent stacks.
Kevin
