Old 04-04-2006, 04:57 PM   #1
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
vent question
I have been up on the roof most of the day re-sealing a mess of 31 years and it has started out as a heck of a job, after 4 hours of work I only have the way back vent and end cap done. When I got up there I noticed the past owners had sealed every rivet All of them on the top can't wait to get a full count how many are up there and the vent and seam on the end cap have some kind of white sealant chalky looking comes off easy with mineral spirits what is it? Anyway my question is the vent I have worked on today is all metal top and all good shape raises fine and all. The 2 front vents I will start on Wednesday may be a problem they work and all look the same as the back one but they have plexy or some kind of plastic on the very top. The second one we have a small leak I think due to the plastic being a little warped. Is this normal on these vents or has someone in the past added this plexy. The plastic parts are riveted on. I would love to replace all the fans and vents but they work and we have no problems with them except that small leak. What I'm thinking is taking the piece where we have the leak and replace with plexy or something any ideas?
Becky
rebel beck is offline   Reply With Quote
Old 04-04-2006, 05:15 PM   #2
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Hi, Becky,
If you have the integrated fan/vent/light/skylight fixtures, yes, they did come with some type of plastic on top of the vents. If your trailer has the rear bedroom, as it appears in your gallery, I can imagine why the back fan's skylight got blocked off.
I think I'm going to replace mine with aluminum covers because the skylights let the inside covers get pretty darn warm about noon time.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 04-04-2006, 05:29 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I would replace the plastic with corrigated Lexan. It give a dispesed light. Has insulating value and is better resistant to sunlight and hail damage. It also makes inside of the trailer a bit brighter. it is available in 1/4 thick sheets (looks like cross section of cardboard) from home stores or hardware.
Old 04-04-2006, 05:59 PM   #4
rebel beck's Avatar
1975 31' Sovereign
Images: 35
Thanks so much for the advice, wonder how hard it is to get the old plastic stuff off.
Becky
Old 04-04-2006, 06:21 PM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Becky
Torch works good , actually not too hard at all, drill the rivets out and use a sharp putty knife to kind of slice thru the caulk. Clean with mineral spirits and bed the new stuff in a bead of Vulkem, rerivet or screw back into place. I reccomend that you use stainless steel fasteners where ever possible on the exterior.
Aaron
WBCCI #XXXX AIR #2495
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 07:03 PM
Vent Covers front two tmeagle1 Roof Vents, Skylights & Fans 1 05-15-2004 09:17 AM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 09:05 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 08:56 PM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 08:44 PM
