Old 09-16-2007, 05:36 PM   #1
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Vent Options
I have seen several threads and posts concerning vent replacements with Fantastic Vents and competitors. My 1983 34 Excella has the combination florescent light/skylight/vent as shown in the attached photograph. The thing is, I like this fixture, once I replaced the florescent works with those from a Thin-Lite that will accept commonly available warm white tubes. One down, two to go. I have converted every florescent tube in the Airstream to warm whites except for the two ceiling vent fixtures in the center and the bedroom, and I seldom use these because of the horrible blue color. They will be fixed. The quality of light from the warm whites is excellent.
My question (finally) is, has anyone done a vent conversion that is compatible with the light fixture in the photograph? The photographs I have seen indicate that the controls for the other vents would be covered and there would be no place for the lights. Simply cranking the vent up operates these vents. Admittedly, there is only one speed and no provision for rain sensors.
Any ideas will be appreciated.
Vaughan
Old 09-16-2007, 06:09 PM   #2
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I think you will find the cover far to restrictive on airflow to be used with the fantastic. If you plan on keeping the Airstream IMHO I think the Fantastic with its lifetime warrenty is the only way to go and it does one heck of a job.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Loosening Vent Handles and Aluminum Vent Replacement kincaidjesse Roof Vents, Skylights & Fans 4 04-16-2007 10:37 PM
Profile options Zed2 Forum Admin, News and Member Account Info 1 01-06-2006 03:47 PM
New toilet options? GlenCoombe Classic Motorhomes 5 09-21-2005 08:37 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 05:29 PM
two more options Zed2 On The Road... 0 02-14-2003 04:08 PM
