Old 06-29-2014, 07:53 PM   #1
Fredrick00's Avatar
1963 24' Tradewind
Denver , Michigan
Vent Help!
Hey all!
I just inherited a 1963 airstream from my grandmother . Only problem is that the rear fan vent cover is missing (over the bathroom) and the living room vent cover is missing (I believe it is 14" x 24"). Vintage airstream supply has the longer one for $150 I cannot afford that but would like to weatherize my girl until at least next summer.
Suggestions and thoughts would be helpful.
Fredrick00 is offline   Reply With Quote
Old 06-29-2014, 08:09 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Modify the outlet to 14 x 14 and install an original or replacement vent.
Old 06-30-2014, 10:01 AM   #3
Fredrick00's Avatar
1963 24' Tradewind
Denver , Michigan
Any info on how this is done would be appreciated
Old 06-30-2014, 10:06 AM   #4
Fredrick00's Avatar
1963 24' Tradewind
Denver , Michigan
Also, I would buy the original longer vent cover if someone has done the modification to the 14x14. Thanks!
Old 06-30-2014, 11:04 AM   #5
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
My suggestion to you is to put a bucked over the opening with a heavy object on top so it doesn't blow away & save up the $150 for a new cover. It's much easier than modifying the opening. Unless, of course, you're going to use the trailer this summer!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 06-30-2014, 11:13 AM   #6
Fredrick00's Avatar
1963 24' Tradewind
Denver , Michigan
Thumbs up
Thanks Becky! We think alike . I have the vent openings covered with sheet metal and duck taped. It works ok but the UV is cooking the tape so I have to change it soon. Thought I might come here to see if there is another (cheap) option I haven't thought of.
Old 06-30-2014, 11:18 AM   #7
Modifying the astrodome flange to a solar dome flange, will cost more than the cover.
The easiest and cheapest fix is get a piece of plastic, and fasten it to the 14 x 26 flange, using a sealer as well.
Use about 20 pop rivets to make the installation. Also, be sure to seal the heads of the pop rivets.
Old 07-07-2014, 09:04 AM   #8
Fredrick00's Avatar
1963 24' Tradewind
Denver , Michigan
Thanks Andy! This is all new to me so this helps a lot!
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
How do I install vent covers over my vent covers? bigjohn Roof Vents, Skylights & Fans 1 07-29-2010 03:34 PM
To vent or not to vent Jammer Mechanics Corner - Engines, Transmission & More... 4 04-02-2010 09:20 PM
louvered stainless steel vent or chrome vent toastie Roof Vents, Skylights & Fans 0 10-18-2009 04:01 PM
Loosening Vent Handles and Aluminum Vent Replacement kincaidjesse Roof Vents, Skylights & Fans 4 04-16-2007 10:37 PM
