Old 03-08-2015, 03:41 PM   #1
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
Vent fan wiring?
Our '67 Safari has one old, possibly original, roof vent fan and the Fantastic Fan that I installed. Since I am rewiring everything now, I noticed that the old fan has red and black wires. This was wired with black wire going to black and white going to red. Normally in DC I would expect that when there are red and black wires, red is positive and black is negative even though when there are white and black wires, white is negative and black is positive. Should I leave it connected black to black and white to red?
Thanks!
JRF0st3r is offline   Reply With Quote
Old 03-08-2015, 04:33 PM   #2
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
Black is hot on mine. I guess it depends on which direction fan spins.
terrencecolp is offline   Reply With Quote
Old 03-08-2015, 07:01 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
On the original red is hot, black to ground. The new system the white is ground and the black is hot. So.... Old red to new black. Old black to the new white for grounds. If you are rewiring it all new, I suggest you run white/black to each, individual, fixture. Then the grounds all to a common grounding bus.
Old 03-09-2015, 07:42 AM   #4
JRF0st3r's Avatar
1967 22' Safari
vent fan wiring?
Thanks!
Fan-tastic Vent 3000BT Fan 110 Volt, 3 Speed, Smoke Dome top, Built in Thermostat? stc cigar Airstream Classifieds 0 02-19-2014 08:45 AM
wiring for vent fan? paul55 Electrical - Systems, Generators, Batteries & Solar 0 03-12-2012 11:02 AM
Fan-Tastic Vent Fan roadliner54 Our Community 2 07-11-2011 11:14 AM
Vent Fan Wiring Ag'71 Electrical - Systems, Generators, Batteries & Solar 2 09-30-2009 08:19 AM
vent fan wiring joel Electrical - Systems, Generators, Batteries & Solar 3 07-06-2005 09:10 PM
