Old 06-02-2008, 07:51 PM   #1
Judy Barde's Avatar
1960 24' Tradewind
pittsburg , Kansas
vent fan
I have a 1960 trade wind and took out the upper fan and re did it to solve a leak. It ran good and I didn't oil or do anything to the fan. It now makes a noise like a rattle after about 5 min. Anyone know if I can put grease or oil somewhere to help it. If so what kind? and where? I have a photo of the fan if that would help
thanks Judy
S. Silver
Judy Barde is offline   Reply With Quote
Old 06-02-2008, 08:11 PM   #2
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Yes, a foto would help.
ArtStream is offline   Reply With Quote
Old 06-02-2008, 09:06 PM   #3
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Sounds like the problem I had with mine. I would suspect they are of similar design.
The bolts that hold the motor halves together are also the mounting points on the bracket. The bearings were loose in the housing. They fit on the motor shaft OK but the blades made the whole thing vibrate. Oiling and greasing didnít change the rattle after it ran for a while.
A normal person would have bought a new motor. However since I tend not to fit that description I split the housing and added another thin piece of felt to the existing one under the spring washer and lower bearing. Then I added a touch of Moly grease to the bearings and put it back together.
Two years and still quiet. I probably just got lucky.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
galley vent fan LHall Lights - Interior & Exterior 0 08-10-2007 12:09 PM
Sure Line Vent Fan Chaplain Kent Roof Vents, Skylights & Fans 1 03-31-2006 09:07 PM
Bathroom fan vent? dustyrhodes Roof Vents, Skylights & Fans 2 12-01-2005 08:17 PM
vent fan wiring joel Electrical - Systems, Generators, Batteries & Solar 3 07-06-2005 09:10 PM
Vent/Fan for sale 14 x 14 from '59 A/S jlawrence Roof Vents, Skylights & Fans 0 04-24-2004 06:56 PM
