Old 04-29-2010, 05:29 PM   #1
RV FyreGuy
Pahrump , Nevada
Vent crank assembly
I am looking for a replacement crank assembly for the roof vent in a 1977 Sovereign. This is a 12'X12" vent with rounded corners and an aluminum lid. The inside is covered by a milk white plastic shroud and light assembly.
Jesse
RVFyreGuy is offline   Reply With Quote
Old 04-29-2010, 05:37 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If its the crank assembly I am think of when mine failed both the dealer and Airstream said the never installed such a thing in their trailers.
A small crank feeding through the plastic lens via a 5/16 dia. shaft and into a small worm gear that raises the vent cover. If that is the one and the gear is stripped just take the gear box apart, drill out the rivets, and move the stripped gear 120 degrees. Only 1/3 of the gear is used so you should have 2 rebuilds available. Reassemble the gear box with #4 bolts and you should be goo to go.
2004 Excursion 4x4
De-rusting window crank assembly pinkflamingoes Windows & Screens 25 12-30-2006 11:14 PM
Vent Crank assembly 1970...inside trim happydaze Roof Vents, Skylights & Fans 0 05-06-2006 02:58 PM
Vent crank assembly milesvdubber Roof Vents, Skylights & Fans 5 09-13-2005 03:27 PM
Front vent won't crank down mavapa Roof Vents, Skylights & Fans 6 09-28-2004 04:18 PM
Ceiling vent crank handle Sneakinup Roof Vents, Skylights & Fans 4 12-02-2003 07:09 PM
