Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 10-31-2009, 08:41 PM   #1
Profile:  1974 29' Ambassador
1976 25' Caravanner
trenton , Missouri
vent confusion
The "skylights" on the Caravanner are cracked and broken. The outside aluminum "vent covers" are fine. Ordering skylights seems confusing. There are vent covers, astrodomes, solardomes etc. Do you order only the plastic parts or are they the entire unit (plastic and aluminum together)? Some kits come with hardward and gaskets. What do I need? I feel like a dummy.
bimpy is offline   Reply With Quote
Old 10-31-2009, 08:48 PM   #2
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
If they are the standard 14" square type various replacements are available such as translucent plastic. If they are aluminum with a plastic center you can replace the plastic with Lexan. Don't use plexiglass. You could also consider upgrading to a Fantastic Fan or Maxx Fan. Photos would help. I have some extra aluminium or tanslucent plastic vents I would sell cheap. Send me a PM if you are interested.
Pay no attention to the man behind the curtain- WoZ
Old 10-31-2009, 08:50 PM   #3
redhawkerII's Avatar
Profile:  1970 27' Overlander
Altus , everywhere GREAT
Images: 14
Send a message via Yahoo to redhawkerII
Try Inland RV on the web...or Andy should kick in there to help clear up your mind.
.....Is there another word for synonym? " Life is like a bicycle...to keep your balance you must keep moving." Einstien, 1930...and lastly,-"Go confidently in the direction of your dreams, Live the life you,ve imagined"...Henry David Thoreau
redhawkerII is offline   Reply With Quote
Old 10-31-2009, 08:51 PM   #4
1976 25' Caravanner
trenton , Missouri
Yes these are aluminum with plastic centers
Old 10-31-2009, 08:52 PM   #5
Commercial Vendor
Profile:  Corona , California
Astrodomes were last used in the 1971 models.
You have "solardomes" only.
Your replace the cover only.
They are available in milk white and solar gray.
The solar gray lets in more light.
They are available, depending on what vendor you choose, in single thickness or with a thermal barrier built in, and with round corners, or square corners. The square corners offer more "tenting" when the cover is opened.
Can't speak for other vendors, but the gasket and instructions come with ours.
You simply remove the old cover and hardware, and install the hardware on the new cover, with the soft aluminum pop rivets.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-12-2009, 09:59 PM   #6
Profile:  1964 24' Tradewind
printer , Kentucky
hey do you have the vents, are they with a fan? I have one with a fan that needs a crank and one with fan that has been seald shut, i would like to be able to open it, the large opening where there was something at one time had a boeard on it, what went there? and do you have what ever that is?
mitsy is offline   Reply With Quote
Old 11-12-2009, 10:12 PM   #7
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Hi mitsy, Take a look here. Replacing Solardome on 1964 Overlander
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-12-2009, 10:35 PM   #8
Commercial Vendor
1965 Airstream trailers had spiral vent operators, that opened and closed both the astrodomes,( 14" x 26") and solardomes (14" x 14").
Plastic covers are available as well as fiberglass.
The plastic covers allow light to enter, the fiberglass covers do not.
Colors are also available, such as white and solar gray.
Andy Rogozinski
Inland RV Center
Corona, CA
Topic confusion. Robbie R. Forum How-To's & Support 5 08-13-2009 07:20 AM
NADA confusion Resorts Trailer Values 2 05-23-2007 09:18 AM
Newbie confusion Don Cook Member Introductions 4 06-18-2006 04:24 PM
12 volt confusion?? COArgosy78 Electrical - Systems, Generators, Batteries & Solar 7 09-21-2004 04:51 PM
Wheel confusion Sneakinup Wheels 11 02-15-2004 10:22 PM
