Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Prev Previous Post   Next Post Next
Old 10-31-2009, 08:52 PM   #8
Commercial Vendor
Profile:  Corona , California
Originally Posted by bimpy View Post
The "skylights" on the Caravanner are cracked and broken. The outside aluminum "vent covers" are fine. Ordering skylights seems confusing. There are vent covers, astrodomes, solardomes etc. Do you order only the plastic parts or are they the entire unit (plastic and aluminum together)? Some kits come with hardward and gaskets. What do I need? I feel like a dummy.
Astrodomes were last used in the 1971 models.
You have "solardomes" only.
Your replace the cover only.
They are available in milk white and solar gray.
The solar gray lets in more light.
They are available, depending on what vendor you choose, in single thickness or with a thermal barrier built in, and with round corners, or square corners. The square corners offer more "tenting" when the cover is opened.
Can't speak for other vendors, but the gasket and instructions come with ours.
You simply remove the old cover and hardware, and install the hardware on the new cover, with the soft aluminum pop rivets.
Andy Rogozinski
Inland RV Center
Corona, CA
Topic confusion. Robbie R. Forum How-To's & Support 5 08-13-2009 07:20 AM
NADA confusion Resorts Trailer Values 2 05-23-2007 09:18 AM
Newbie confusion Don Cook Member Introductions 4 06-18-2006 04:24 PM
12 volt confusion?? COArgosy78 Electrical - Systems, Generators, Batteries & Solar 7 09-21-2004 04:51 PM
Wheel confusion Sneakinup Wheels 11 02-15-2004 10:22 PM
