Old 08-28-2007, 11:39 AM   #1
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Vent Actuators
My 62 Ambassador has the Ladeau vent actuators. I recently purchased some used ones on Ebay to refurbish the larger vent as it was missing the actuators. What would be the best lubricant to use on them? I have cleaned them and removed the corrosion with WD40. I was thinking about white lithium grease or possibly another type of grease.
Any recomendations?
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Old 08-28-2007, 02:27 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Any recomendations?
I would use a very very slight amount of Vaseline. It is not a good idea to over-lube these actuators, as they will have a tendency to open while driving due to the vibrations of the trailer. I suggest you just clean them real well, and then leave them alone..a little friction will prevent the vents from opening while driving.
Frequent use will help keep them working well. They corrode when sitting unused for a long time.
Uwe
www.area63productions.com
Old 08-28-2007, 03:27 PM   #3
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
Thanks for the information. I had thought of Vaseline, but was unsure since the parts are aluminum. I thought it may be too thick. I will give it a try.
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
Larger Fan Blades in top Vent Sav'h Steve Roof Vents, Skylights & Fans 5 07-09-2003 05:35 PM
1985 Excella shower vent fan gimmejul Roof Vents, Skylights & Fans 8 05-01-2003 07:56 PM
Power lift vent with fan. fphil Roof Vents, Skylights & Fans 4 10-05-2002 07:44 PM
vent fans missing/not working Rog0525 Roof Vents, Skylights & Fans 2 07-02-2002 04:23 PM
