Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 03-16-2009, 12:40 PM   #1
katzklaw's Avatar
Profile:  1964 26' Overlander
Abilene , Texas
Send a message via AIM to katzklaw Send a message via Yahoo to katzklaw
Rivet those darn skylights...
seems that they are a big issue with alot of Airstreams. mine was sealed shut when we got the trailer, and we didn't mess with that. until recently
it still leaked a bit, even though it was sealed up. hubby got tired of dealing with it and crawled up to take a closer look. it was caked with silicone, but apparently in all the wrong places, because it obviously wasn't stopping the leak... and the lid for the skylight was held down with 8 screws, 2 on each edge. he removed all those, and now the skylight actually works, despite one missing crank handle (it still works if you put a screwdriver into the hole and turn) and once hubby sealed the 8 screw holes it also no longer leaks. our problem now is.. we don't have trim for it... so its an ugly hole in the roof... AND, since it was sealed shut when we got it, the screen is long gone. anyone have an idea where we can get a screen and/or trim?
thanks!
hey look, its another Airstream blog!
katzklaw is offline   Reply With Quote
Old 03-16-2009, 12:59 PM   #2
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Skylights allow great amount of light into the coach....vista views do as well. I specifically opted not to have a skylight installed and from the sound of the general folks out there replacing them even on fairly new units, it seems to have been a sound decision...however, I do wish I had a few vista views.
For vintange, I would check with vintagetrailersupply or inland rv.
Old 03-16-2009, 01:10 PM   #3
Silverwanabe's Avatar
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Images: 101
Airstream Registry
VTS and Andy both have replacements.
The less windows and vents, the better off.
Less chance for leaks and warmer in winter.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
Website: http://piedmontunit.wbcci.net/ welcome/
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 03-16-2009, 01:46 PM   #4
Profile:  1963 24' Tradewind
San Diego , California
The screen and screen frame is the same as a house screen. There are 2 different frame thickness, you want the thinest one. you also need to have a gromet installed at each crank. Your other vent screens should be a good example. Do you have the 4 little clips to hold the screen in? Good Luck! most glass co's. make custom screens.
Sixty3TW4US is offline   Reply With Quote
Old 03-16-2009, 04:50 PM   #5
katzklaw's Avatar
Abilene , Texas
hmmm. shouldn't be a problem to get a screen made... but color me confused as how to install it. i need a gromet at each crank? i guess the crank handles come off for screen installation? i have no idea how to go about removing the one handle i have left, tho. and i have no little clips at all. anyone have a pic of a correctly installed screen i can compare to?
and as for looking at my other vents for comparison... none of them are original, they're all the square vents you can buy from any RV parts store, and those come with their own screens with a super-skinny plastic frame. i think i'm going to replace them with fantastic fans in a few months :-/
Old 03-16-2009, 05:10 PM   #6
The handle has a small hole, i think 2 small holes, in one of the holes push with a small nail or an awl it should release the handle. you will be pushing in a small ball to release the handle. The gromets are the same ones that are on a tarp. I will try to get a pic for you.
Old 04-04-2009, 12:38 AM   #7
Profile:  2004 25' Classic
Lawton , Oklahoma
A hail storm made a hole on the outer dome of the skylight. What is the cost to replace?
Okie1 is offline   Reply With Quote
Old 04-04-2009, 08:46 AM   #8
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Airstream Registry
I'll take a couple of pictures of our '64 skylight once I get out there today. Its about 30 & snowing right now...but we going out anyway to finish some more wood for our '56.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 04-04-2009, 09:50 AM   #9
Profile:  Corona , California
What size?
What color?
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-04-2009, 10:49 AM   #10
FLYNCLD's Avatar
Profile:  1962 22' Flying Cloud
Bend , Oregon
Screen Picture
Check the phone book for people that do screens. In our town there is a guy that does mobile work and will come to your place. As for the trim, I am going to redo mine in wood, however if you want to stay more original, go to a heating and duct work shop with a template of what you need, and they should be able to whip one up. Make sure you have them use aluminum however, as most duct work is galvanized! Here is a picture of the screen with grommets.
Name:	Window Cleaning.jpg
FLYNCLD is offline   Reply With Quote
Old 04-04-2009, 03:45 PM   #11
InsideOut's Avatar
1956 22' Safari
Images: 87
Airstream Registry
Between coats...
Originally Posted by InsideOut View Post
I'll take a couple of pictures of our '64 skylight...
Here are some pics of ours in our '64 GT. There aren't any "clips" on ours to hold it in place, it's just held by the two knobs. There are set screws to remove the knobs and take the screen off.
Shari
ID:	77886   Click image for larger version
Old 04-05-2009, 11:36 AM   #12
Lawton , Oklahoma
Thanks everybody, I went on the roof with some tape, liquid nails sealant, and scissors, covered the hole for now, but while up there I discovered the AC cover is also damaged from the side I could not see from the ground. So, it will go to the local RV shop to get it replaced. I enjoy all the input. My heart breaks to hear of all the damage in the Austin, TX area. Here in Lawton, OK the wind has been blowing hard, hard to stay on the roof of the RV. God be with all of us. VC
Classic 34 skylights Resorts Buyer Guidelines 6 05-22-2007 03:59 PM
skylights to replace vents for '64 safari fancy pants Roof Vents, Skylights & Fans 2 12-10-2006 12:25 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 07:26 PM
darn 53flyingcloud Sprinter and B-van Forum 0 04-15-2005 12:34 AM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 08:32 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
