Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 06-11-2008, 04:08 PM   #1
Lothlorian
Profile:  1973 27' Overlander
Loganville , Georgia
Thinking of replacing all vents?
I was so happy with the success I had with installing a Fantastic fan I was considering replacing all my vents. Both other vents have issues. On the motor and crank screw are broken. It is also missing some parts so it will not crank up or down and it leaks. The other vent will not close all the way because the bar is bent. I tried to straighten out the bar but that was not working. Has anybody in the forums replaced all their vents with newer vents?
SIU Bound
Brian
Lothlorian is offline   Reply With Quote
Old 06-11-2008, 04:30 PM   #2
markparker22
Profile:  1984 31' Excella
Santa Barbara , California
I replaced all three original vents with Fantastic Fans and added a thin fluorescent fixture next to each. Superior lighting and better air control, especially venting kitchen odors.
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 06-11-2008, 04:49 PM   #3
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
keeping rv cool during extended parking
Greetings Brian!
I too have replaced all of the factory square vents in each of my coaches. I have no regrets, the Fantastic Vents are much more efficient than the factory originals -- and if you go with the model that has thermostat and rain sensor you can safely leave the vents open when away from the coach. These vents are a must-have if you ever attend rallys where the maximum electric is 3-AMP.
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 06-11-2008, 04:58 PM   #4
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
My Gt has two overhead fans that will get two new Fantastic fans that live in my basement as we speak. I just haven't gotten to it yet.
Aerowood is online now   Reply With Quote
Old 06-11-2008, 05:54 PM   #5
overlander63
Rivet Masher
overlander63's Avatar
Profile:  Bay Area , California
We now have two Fantastic Fans in place of the chintzy replacements for the original vents. I think only two need to be powered, though. Any more than that, and you could get a swirling vortex of whatever is lying around in the trailer when you turn them all on.
overlander63 is online now   Reply With Quote
Old 06-11-2008, 07:46 PM   #6
Lothlorian
I am sold on replacing all the vents. When I buy the new fans I will shop for some good replacement lighting where the old vents go. I do like the incandescent look. I am not a big fan (no pun intended) of Florescent lighting.
Brian
Old 06-11-2008, 07:49 PM   #7
overlander63
Rivet Masher
Brian
A couple advantages to flourescent is they use less electricity, are cooler (important in Summer when boondocking), and usually last longer than incandescents. You can use white LED's for the same effect, but they aren't as bright.
Old 06-11-2008, 09:52 PM   #8
Mexray
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
Here's some pics of my vent changing progress...I've got all three of them replaced now. I installed recessed 'spot' type lights from Dr LED to replace the lighting fixtures that were part of the old vents.
I got my vents from Vintage Trailer Supply...they have the flat top type Fantastic fans in gray color, and include the inside trim piece that has a curve to match the AS interior...neat!
It's a real 'fun' job to get all the old 'gunk' off the roof! I finally got smart and use a heat gun to soften it up and it then came right off. Trimming the outer and inner skins to fit the new vents is an easy job if you pick up a couple of cheap type RH and LH cutting tin snips.
Now that it's done, I'm happy with the results. I used a fan with a thermostat in the mid bedroom area, a plain fan over the Galley area, and a vent without a fan in the forward area...I thought 2 fans would be plenty...I can crack the front window open, turn on the fan over the galley and get a nice cross breeze! My thinking was that the thermostat unit would work best over the beds, as it can cycle on and off in the evening when we're sleeping if its warm outside to get the air flowing...
I believe that Vintage Trailer Supply is the only company that handles the gray, flat top Fantastic fans...they give great service, and the price is competitive.
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated
Old 06-12-2008, 03:54 AM   #9
Lothlorian
MexRay:
How does the aluminum hold up under the heat of the heat gun. I have used a heat gun before to fix rips in vinyl. Those heat guns get really hot.
Brian
Old 06-12-2008, 09:09 AM   #10
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
We swapped two of the original vents for the Fantastic variety last year. I purchased the grey colored, flat lid vents from Steve @ VintageTrailerSupply.com. I took them along with me to the International Rally and had the pros from Fantastic Fan install them at the Rally. Great opportunity to take advantage of their talents. They replace 100's of vents every year, so they know how to do it right. They also provide outstanding support if you have problems down the road. We replaced the lighting with Thin-Lites, which make more useful light and use less battery power.
Note: the Fantastic Fan vendors did NOT have the grey/flat lid style with them at the International last year. They were apparently a special order run just for Steve Hintgen.
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-12-2008, 12:07 PM   #11
dnrtheil
dnrtheil's Avatar
Profile:  1964 24' Tradewind
Portage , Michigan
I am looking for a vent fan motor for my '64 Tradewind, if any of you guys that took your old vents out have one taking up space in your homes!!!
Thanks - Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 06-12-2008, 12:21 PM   #12
bedfords
bedfords's Avatar
Profile:  1972 27' Overlander
1975 29' Ambassador
Littleton , Colorado
Motor Replacement
Thanks - Derek
Derek let me look around I think I might have one for you. If you don't hear back in a day or so remind me (the in-laws are coming to town).
Joe
Master of the Tin-Can
and thats not saying much
bedfords is offline   Reply With Quote
Old 06-12-2008, 12:23 PM   #13
bedfords
bedfords's Avatar
1975 29' Ambassador
Mexray
Thanks for sharing your photos. It looks great!!
Old 06-12-2008, 12:32 PM   #14
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
We have one Fantastic Fan installed on our GlobeTrotter and two ready to be installed on our Safari. The GlobeTrotter's lid is smoked plexi and the Safari's are the grey - they didn't have the solid grey when we ordered the one.
The only two complaints I have are:
1) the plexi one is over our bed and lets campground lights in from above at night - it hits right on our heads.
2) the thermostat/automatic setting is very sensitive to moisture. It cycles on/off all night with heavy dew and is pretty noisy. So we don't really use it.
We will be replacing the plexi one with a grey one on the GT once we are finished with the Safari. The lids are not interchangeable, I asked.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Repairing or Replacing Roof Vents klevan Roof Vents, Skylights & Fans 18 02-04-2007 09:48 AM
Thinking About baysidegal Member Introductions 2 11-24-2006 07:48 PM
Thinking twice about AS.... outthere 2007 Safari 11 11-03-2006 05:47 PM
Thinking about replacing oven with microwave Stefrobrts Stoves, Ovens & Microwaves 36 01-15-2006 11:02 AM
Replacing roof vents JAD Roof Vents, Skylights & Fans 10 04-15-2004 10:37 PM
