Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Roof Vents, Skylights & Fans
Old 06-12-2008, 02:10 PM   #15
crispyboy
crispyboy's Avatar
Profile:  1981 22' Excella II
alexandria , Kentucky
How do you get power to the powered vents?
crispyboy is offline   Reply With Quote
Old 06-12-2008, 02:17 PM   #16
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
In the case of my Tradewind, one vent has a powered fan. For the others, you tap in to the 12 volt power of the lights adjacent the vent opening.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 06-12-2008, 02:24 PM   #17
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Fantastic Fans run on your battery. If your old vent had a fan, then the wiring is already there. If it didn't have a fan...it may also already be there in newer trailers - alot of them were pre-wired. If there isn't power, then you can run it in the ceiling down the wall without too much trouble if there isn't a ceiling light nearby. We just ran Romex for our second fan in our Safari across the ceiling and down the wall. I was really surprised how easy it was...I was expecting cross member supports (running the length of the trailer in the ceiling) interfering...but there were none.
You'll most likely will have to remove your old vent/fan in order to tell it it is pre-wired or there are other accessible wires nearby.
As an alternate, you could attend an International or Regional WBCCI Rally - Fantastic Fan always has reps & installers there to install them for rally attendees. That's what we did with our first one.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 07-02-2008, 05:41 PM   #18
AZ-JH
AZ-JH's Avatar
Peoria , Arizona
What can we expect to pay to have the bedroom vent replaced with a Fantastic Fan in a 2006 Safari 25 FB? Since the vent is there now, does that mean the wiring is accessible for a Fantastic Fan?
AZ-JH is offline   Reply With Quote
Old 07-02-2008, 10:13 PM   #19
Aage
Profile:  Currently Looking...
Aurora , Ontario
This video gives you a good idea of the complexity level required.
I don't have a platform scissor lift, so my issue would be the need to not come crashing through the roof.
It's not rocket surgery, but you need to be comfortable with cutting the aluminum roof and inner skin. I know that's not for everyone.
Old 07-02-2008, 11:20 PM   #20
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 70
Originally Posted by InsideOut View Post
We have one Fantastic Fan installed on our GlobeTrotter and two ready to be installed on our Safari. The GlobeTrotter's lid is smoked plexi and the Safari's are the grey - they didn't have the solid grey when we ordered the one.
The only two complaints I have are:
1) the plexi one is over our bed and lets campground lights in from above at night - it hits right on our heads.
2) the thermostat/automatic setting is very sensitive to moisture. It cycles on/off all night with heavy dew and is pretty noisy. So we don't really use it.
We will be replacing the plexi one with a grey one on the GT once we are finished with the Safari. The lids are not interchangeable, I asked.
Shari
Shari - so what you're saying is you will have a slightly used Fantastic fan available at a fantastic price?
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is offline   Reply With Quote
Repairing or Replacing Roof Vents klevan Roof Vents, Skylights & Fans 18 02-04-2007 09:48 AM
Thinking About baysidegal Member Introductions 2 11-24-2006 07:48 PM
Thinking twice about AS.... outthere 2007 Safari 11 11-03-2006 05:47 PM
Thinking about replacing oven with microwave Stefrobrts Stoves, Ovens & Microwaves 36 01-15-2006 11:02 AM
Replacing roof vents JAD Roof Vents, Skylights & Fans 10 04-15-2004 10:37 PM
