Old 08-15-2010, 03:39 PM   #1
1959 24' Tradewind
Excelsior , Minnesota
stove and heat vents
Hi, I'm redoing a 59 Tradewind, In putting the vents on the backside I don't want to put them on when there are still big holes in the sides, I can't remember what goes to these holes. I'm guessing its a stove pipe or something of the sort if anyone can help me I would appreciate it, took her apart about three years ago and even with photos can't remember this part of the puzzle. I don't want critters to be able to get in. I've been matching up Rivet holes but I don't have the pieces that go over the circular cut out into the the RV. I'm tempted to put some sort of screen but just don't want to have to remove the vents to do it correctly later. THANKS!
59as is offline   Reply With Quote
Old 08-16-2010, 03:30 PM   #2
1965 24' Tradewind
Nicholasville , Kentucky
Hey, working on a 65 Tradewind and the only things I can think of is about a 6" diameter hole above the cooktop that has an exhaust fan in it (cover on the outside) The heat in mine exhausts out the side. There is a intake and exhaust one over the other, but it is an electronic ignition addition 14-15 years ago.
You dont have any photos of the duct work under the floor do you, that's what I'm needing to get in my mind.
Dr Dan is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
Plumbing, AC, and Stove Roof Vents bvanetten 1967 Overlander 1 07-28-2008 10:15 PM
How bad can it really be to "heat" with the stove or oven? Chuck Stoves, Ovens & Microwaves 26 08-24-2007 07:27 PM
Diesel Stove/Heat/Hot Water keylime General Appliance Topics 6 12-09-2002 07:03 AM
