Old 09-27-2009, 03:18 PM   #15
Smile Good Job, Kevin
I have 65 tradewind and might put in permanenet instead of raisable skylight, but you give me good hints. Tks
bdlwet is offline   Reply With Quote
Old 09-28-2009, 01:54 PM   #16
dpandorf's Avatar
2000 34' Limited
Somewhere in Western , North Carolina
New Maxim enroute
After reading this thread last week as we've been solving our own water leak issues, decided to "permanently" replace our two skylights.
After a couple phone calls with David Thornton at Maxim, I placed the order and the two skylights are expected to arrive this Wednesday.
Looking forward to installing these.
Duane Pandorf
Blog | Google+
Air# 16888 | 2000 34' Limited | 2008 Ford F250
dpandorf is offline   Reply With Quote
Old 09-28-2009, 04:15 PM   #17
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
Delivery time?
Nice post, Kevin.
How long does it take to get delivery from the day you order them?
Thanks.
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 09-28-2009, 04:19 PM   #18
dpandorf's Avatar
2000 34' Limited
I ordered mine last Wednesday and they shipped today and delivery is this Wednesday. Shipping is not cheap as they will not use FedEx ground. You'll need a commercial address to ship to. I'm using a friends contractor's office which is just up the road from where I live.
Duane Pandorf
Blog | Google+
Old 09-28-2009, 09:45 PM   #19
dpandorf's Avatar
2000 34' Limited
Weather forecast for new Maxim Sunlight install
Its been raining cats and dogs that last couple weeks here in the mountains. My new skylights are expected to arrive on Wednesday and I plan on installing them on Thursday.
Brevard, NC weather forecast
Then we hit the road for 2 months once that's complete.
Duane Pandorf
Blog | Google+
Old 10-24-2009, 08:27 PM   #20
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
Replacing OEM skylights with Maxim Skylights
Bambi Bandit... Want to thank you for your detailed instruction on mounting the Maxim skylight. In your pictures of the installed skylight I can see a number of bronze colored screws on the top of the frame as well a some on the sides of the frame that were not caulked. I see that you caulked all of the screws you installed to mount the skylight down to the sides of the trailer installed frame but did not caulk the others. Just wanted to know why you did not caulk the other screws.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 10-24-2009, 09:13 PM   #21
dpandorf's Avatar
2000 34' Limited
I just got online and saw an update to this thread and wanted to respond to your question since I've also installed the Maxim's on my stream too.
The link below is to a PDF from the Maxim website and shows a diagram of how the skylight is put together. The only screws that could allow water into the trailer are those that Bambi has caulked horizontally into the side of the curb that sticks up from the roof of the trailer. The other screws are those that hold the skylight in the frame itself.
Maxim skylights
Plus I've posted a photo of the curb mount image:
Duane Pandorf
Blog | Google+
Old 08-20-2010, 10:00 AM   #22
silverbacksurfer's Avatar
2005 25' International CCD
Glendale , California
I have been waiting all year for the summer, no rain, to start this job in between camp trips. I built some scaffolding with 2 8' a ladders. Just got the old skylight off calling Maxium to order.Fun stuff worked just like the step by step instruction from Bambi bandit. Thanks . Will let you know how it turned out when I get the new skylight.
silverbacksurfer is offline   Reply With Quote
Old 08-20-2010, 10:30 AM   #23
maxim skylights
Just talked to Liz @ Maxim they will ship to a residential address.
Old 09-07-2010, 12:02 PM   #24
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I just ordered my Maxim Skylight today!!
Stoked and ready to get the unit installed. I went for a bronze, clear, clear (dome, dome, flat) skylight, with a Bronze powder coat frame.
Thanks to Bambi Bandit for the step by step instructions. We developed a small leak at the skylight, and when I went to investigate, it was clear the the unit had been over-torqued and virtually every screw attachment was cracked.
I scraped off the old curb caulk, re-sealed the curb, and am waiting for the replacement unit.
The folks at Maxim were very helpful and immediately knew what I needed for the AS.
I will post a picture of the finished product.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 09-07-2010, 02:35 PM   #25
2007 25' Classic
Hydes
Once you replace the cheap and poorly installed Airstream OEM skylights, replace the water pump,fix the cabinets, caulk the leaks, touch up the corrosion, replace the tires and install a working brake actuator, These Airstream aren't to bad. One day the quality may even equal the price they charge. I installed my Maxim skylight about 4 months ago. .
craftsman is offline   Reply With Quote
Old 09-07-2010, 02:47 PM   #26
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I'm Glad they put cheap ones on as incentive to upgrade.
Since we did it ourselves, we know our Maxims are installed correctly.
Ken
Old 09-07-2010, 04:04 PM   #27
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I see that they have offices in both Florida and Texas. Do you know where Liz is located?
I think I'd like to put these on my trailer. One of the skylights started leaking on our last trip and when I went topside I found what many others have found - the skylight flanges were cracked at just about every screw hole. I gooped it up for now and stopped the leak, but of course I would like a better fix. I was surprised at how flimsy the original skylights are.
We will be travelling to the southwest this winter and i wondered if I could order them and pick them up at their Dallas-Fort Worth office - or maybe even have them installed there.
I emailed twice with no reply at all so I guess I need to phone.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-07-2010, 04:30 PM   #28
Ag&Au's Avatar
Brian
Hi Brian,
Both Liz Ibarra and David Thornton are in DFW. I dealt with David.
Here is his info:
DAVID THORNTON | Maxim Industries, Inc.
1630 Terre Colony Court | Dallas, TEXAS
888-222-4898 toll free |214-905-2021 local |214-905-2024 fax |(+44)020-7096-8920 intl
Liz usually answers the phone. Her email is Liz@maximskylights.com.
Surprisingly David email is David@maximskylights.com.
I am 99% sure they do no installations.
There are great to deal with.
Regards,
Ken
oem skylights, replace
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 02:23 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 07:26 PM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 08:32 AM
