Old 07-03-2015, 07:29 PM   #239
1962 19' Globetrotter
2001 31' Excella
Thanks to this thread, great success replacing my skylight today! Only problem now it that the trim looks terrible agains the new skylight. Not to mention I broke it a few times... Has anyone replaced this as well - or know how it is removed and replaced? Thanks!Click image for larger version
Name:	ImageUploadedByAirstream Forums1435969736.942303.jpg
ID:	242154Click image for larger version
Name:	ImageUploadedByAirstream Forums1435969752.678298.jpg
Craig is offline   Reply With Quote
Old 07-03-2015, 08:30 PM   #240
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I replaced both of the skylight trims on my Excella last year when I installed new skylights. There are four screws, two behind each of the shade's ends.
Trim Ring, 14in X 22in, Skylight White 201963 [201963] - $92.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
or
Trim Ring for 19 1/2 X 19 1/2 Skylight 201962 [201962] - $73.76 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Alan
Old 07-22-2015, 10:17 AM   #241
2004 28' Classic
Medical Lake , Washington
An old thread that is still great for directions for replacing skylights. Replaced both on my 2004 Classic. They were way past due for only caulking was holding them in place. Unit is new to us, was surprised to find the poor condition of the skylights. The Maxim skylights are the only way to go.
Classic2004 is offline   Reply With Quote
Old 07-22-2015, 10:25 AM   #242
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Are the skylights for mid 2000 Classics all the same size? What were the dimensions you forwarded to Maxim?
Kelvin
Old 07-22-2015, 01:46 PM   #243
dznf0g's Avatar
Oswego , Illinois
Can't say if they are all the same. Measure you existing curb and call maxim. They are well aware of needed lite for your curb.
-Rich-
Old 07-22-2015, 02:13 PM   #244
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Kelvin
When I ordered for my 2010 (very early in 2010 model year), Airstream had just changed the dimensions. I did not know this and neither did Maxim. I used Maxim's "standard Airstream dimensions" at their suggestion. They did not fit. Maxim replaced them at no cost to me.
The lesson learned:
Always get your exact measurements to save the time and annoyance of return and replacement.
Airstream changes stuff like that and apparently never tells anyone.
Ken
Old 07-23-2015, 11:13 AM   #245
2004 28' Classic
Kelvin,
The size that David had for my 2004 were the right size for both front and back skylights. Rear 17.25 x 25.25, front 22.25 x 22.25. The size that was listed in the Airstream parts manual are not correct, not sure how they measured more like the inside of the curb not outside of curb, finished size? Makes it harder to replace??
I was really happy not to have pull the skylights, measure, reseal and wait for replacements. Getting up on the roof and doing it once was enough, multiple times no fun.
Really cannot understand why Airstream puts such poor quality skylights on such expensive units. Not that much difference between junk and a top notice product that will last a life time.
Vern
Old 07-23-2015, 11:22 AM   #246
dznf0g's Avatar
Oswego , Illinois
Caution: Please measure...my 2007 are not the same as Vern's. My front is a square, but the rear is a rectangle, so there are obvious differences.
You can easily measure close enough for Maxim to advise you by removing the interior trim and measuring the inside dimensions of the curb. Maxim has a pretty good file of the correct sizes for ASes. They'll know which you have, just tell them that you have the original AS curbs and tell them you measured the inside curb dimensions. Yes, there is a flange on top, but they know that.
You can also climb on the roof and measure the dimensions of the flanged area. You can see it through the old AS lite.
-Rich-
Old 07-23-2015, 09:20 PM   #247
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The "production" drawings Airstream sent to me of the roof flanges somehow did not reflect the reality of their building the flanges......
Old 07-24-2015, 11:41 AM   #248
dznf0g's Avatar
Oswego , Illinois
And you were surprised at that?????? Jus sayin'
-Rich-
Old 07-26-2015, 11:28 PM   #249
2004 28' Classic
The measurements I provided are for a square front skylight and rectangle is rear.
Vern
Old 01-25-2016, 10:19 PM   #250
asv2's Avatar
2008 25' Safari
Jacksonville , Florida
Maxim vs OEM weight & other questions
Maxim skylights sound wonderful. Our 2008 25' Safari has leaks - I have appointment to get recaulked/resealed at the airstream dealer. Just realized it's a perfect time to replace the skylight which is probably part of the problem, not to mention it's cloudy and ugly.
Im a newbie so forgive if this is silly question/concern.
Everyone has said how lightweight and flimsy the OEM skylights are. Liz at Maxim said the Maxims weigh about 21 pounds. I wonder if maybe that's why Airstream uses the lightweight skylights, i.e. to keep the overall weight of trailer less? Being a newbie I'm concerned about keeping the load light, since everything weight wise can add up faster than you think.
Other questions:
Does anyone know about how much the OEM skylights weigh?
For those who have had Maxims a while, how are they maintaining their clarity?
For those who have the bronze, clear, clear Maxims, are you able to see stars at night through them?
asv2 is offline   Reply With Quote
Old 01-26-2016, 05:07 AM   #251
dznf0g's Avatar
Oswego , Illinois
IMO, they are worth the weight. OEM is probably about 5 - 7 pounds. Clarity is great. ..just don't use window cleaner on them. Soap and water only. Stars are very clear.
-Rich-
Old 01-26-2016, 05:20 AM   #252
switz's Avatar
2014 31' Classic
Images: 8
We put the Maxim frosted white lenses above the bathroom in the Classic. That is their best light diffuser for inside light and block the most heat gain. We used the middle bronze tint for the front unit and you can see the stars at night through it. We also put the frosted white on the 23D as there was only single skylight.
oem skylights, replace
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 10:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 08:49 PM
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 03:23 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 08:26 PM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 09:32 AM
