Old 10-10-2014, 06:53 AM   #211
dznf0g's Avatar
Oswego , Illinois
Originally Posted by BigAl View Post
If the sub frame of the skylight is caulked to the curb and not leaking why wouldn't you just replace the acrylic dome and reuse the retainer? That's all I do on residential installations when a dome fails.
Al
Maxim would be worried about air leaks between layers and condensation. That is what I was told while Maxim was resolving a warranty issue with me. They sent new assemblies. They don't endorse repairs to the sealed layers.
-Rich-
Old 10-10-2014, 07:11 AM   #212
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The OEM skylight is a single piece of thin acrylic, not worthy of any application, taped or caulked to the curb. The Maxim is a triple-glazed, well-designed dome within a strong frame. There may be others as well but anything is better than the OEM.
Larry
lsbrodsky is offline   Reply With Quote
Old 10-10-2014, 08:37 AM   #213
1994 30' Excella
Mississauga , Ontario
I thought they were put together the same as the ones I used which were made in Canada. On mine there is a gasket on the bottom frame that the dome sits on. Therefore the dome is able to expand and contract independent of the frame. The two layers of acrylic are sealed to each other like a thermopane glass unit.
Sorry for the confusion.
Al
Al and Jean
TAC ON-3
Old 10-10-2014, 03:02 PM   #214
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Two Box Trucks
A polishing thread from long ago showed a rally - where group polishing was happening. One of the best ideas ever? They had two box trucks - one on either side of an Airstream, and they just pulled the Airstream through while lying down on aluminum ladders with plywood covering them. Polish a foot or two, move the Airstream forward, continue, etc.
I know someone with a fleet of small box trucks. If I completely lose my mind and decide to upgrade my A/C myself and/or install a Maxim, and replace the the plastic shower and bath vents, and put Capt. Tolley's Creeping Crack Cure on every rivet on the roof.... I'm gonna borrow or rent them thar trucks!
Paula
Old 10-10-2014, 03:07 PM   #215
Originally Posted by zenstream View Post
Great detailed post. Although the skylight in my 2014 International Signature doesn't leak, this and other posts about leaking skylights make me wonder if it is just a matter of time. Right now, I'm more interested in insulating my skylight from the intense sun/heat as I travel the west.
Thinking of just going to Home Depot and getting a 19"x19" piece of stiff styrofoam to stick above the accordion blind during the day. Are their better solutions?
Best,
Rob
Sew a big elastic bordered shower cap made of prodex and put it on the roof whenever you camp. With luck and a stepladder you could probably snag it over the edges of the skylight with an awning hook. Getting it back off? Eh? The wind will take care of that.
Old 10-11-2014, 07:06 AM   #216
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Exactly the same advice I got from Maxim.
As mentioned earlier, the condensation between the two dome layers did evaporate from mine but I was almost certain it would return So I tried to remove the entire assembly t replace it and found it was not going to be an easy task - I really do think that the only way I can get it off now will be to carefully cut the whole thing off piece by piece - probably will use one of those newer type oscillating saws with metal cutting blades, I have one and tried it on some scrap aluminum and I think it will do the job fine.
Since I know that will be a big job, I decided that for now I would really try to do a good caulking job on the skylight that is in place and see what happens.
I did that early last Spring and to date, the condensation has not returned.
I suspect it is only a matter of time though and am ready to go at it whenever I have to!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 10-11-2014, 08:32 PM   #217
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We cut an oversized piece of Reflectix and put above the accordion shade. Works great and I can sleep in....
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-05-2014, 08:17 AM   #218
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
I just purchased a Maxim from Out-of-Doors Mart. They suggested using double sided tape instead of caulking. Has anyone used tape instead of caulking?
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 11-05-2014, 08:32 AM   #219
lsbrodsky's Avatar
I asked Maxim about that and they do not recommend tape at all. They get some special stuff for their layers but they say you cannot get anything that will work as well as adhesive caulk.
Larry
Old 02-09-2015, 08:48 PM   #220
TinyTin
TinyTin's Avatar
2006 25' Safari
San Antonio , Texas
Cool Adding Maxim Slkylight to 2005 25" Safari
I am just beginning to replace the amazingly cheap skylight that Airstream installed. WHAT WERE THEY THINKING?? Every screw hole was cracked I had water gushing in like a submarine with a screen door!!!. They had to see that??? I worked with Liz at Maxim and she was a dream to deal with. I am using Sikaflex-221 as my sealer. I have used it in the past and has great flexing properties. I really hope that Airstream is reaching out to this company to begin using their product as a standard on all the new trailers. Airstream please listen to your faithful customers.
TinyTin is offline   Reply With Quote
Old 02-09-2015, 09:01 PM   #221
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You will be a "happier camper"!!! 😜😁😄
Channing
WBCCI# 30676
Old 02-09-2015, 09:44 PM   #222
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Maybe one could install one of the replaced Airstream skylights in the ceiling of the shower stall. Then every times it rains, the whole family could take a shower without diminishing the precious fresh water supply.
Everything has a purpose. It just needs to be discovered.
Let me know if anyone finds a useful purpose for a politician.
Ken
Old 02-10-2015, 07:46 AM   #223
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Ground up for pig food?
Old 02-11-2015, 12:11 AM   #224
2007 22' International CCD
Too rich, too fat--bad for the pigs.
KE4GNK/AE
oem skylights, replace
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 02:23 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 07:26 PM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 08:32 AM
