Old 05-19-2014, 08:43 PM   #183
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
So, you're leaving the existing frame in place and screwing the new skylight frame to that, and caulking between the new frame and the existing frame? I had wondered about having a skylight made that would accept the existing roto-openers- this isn't our trailer but is exactly like it. Do your skylights open?
And, I think we'd go for the clear- I had the skylight out and the daylight into the trailer was really nice.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 05-20-2014, 09:13 AM   #184
switz's Avatar
2014 30' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We went with clear-white-clear for the bathroom area and clear-bronze-clear for the kitchen area. The diffuser in the white area really helps brighten up the bath area and I was told by Maxim it was their best heat gain blocker.
Old 05-20-2014, 02:11 PM   #185
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Try bug and tar remover made from citrus or simple green then rinse with water and apply some wax.Use a micro fiber cloth so you don't scratch cover.
Old 07-01-2014, 06:25 PM   #186
Maxim Skylights
Dallas , Texas
Maxim Skylights: Cleaning Instructions
Originally Posted by A W Warn View Post
I got clear/clear/clear. Happy so far.
One of my skylights has a big blob of pine sap on. How should I clean that? Mild detergent and water will not touch it.
Please see the attached cleaning instructions for Sheffield Makrolon polycarbonate. I hope this is helpful and please share.
MaximSky is offline   Reply With Quote
Old 07-01-2014, 06:32 PM   #187
Maxim Skylights
Dallas , Texas
Maxim Skylights: Sheffield Makrolon Cleaning Instructions
Sheffield Makrolon Polycarbonate Cleaning Instructions
Old 07-01-2014, 06:40 PM   #188
reinergirl's Avatar
Hollis , New Hampshire
Thanks Maxim, that's great info. I love my Maxim skylight !
reinergirl is offline   Reply With Quote
Old 07-01-2014, 08:02 PM   #189
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Thumbs up Excellent customer service!
David,
Thank you for posting the cleaning instructions here.
And thank you for the copy you emailed directly to me. It is filed for future reference!
Alan
Old 07-02-2014, 12:02 AM   #190
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
Thanks Maxim. We LOVE our Maxim Skylights!- Brad and Maggie
SuperTrouper is offline   Reply With Quote
Old 07-02-2014, 10:06 AM   #191
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
OK, OK, y'all convinced me, I just ordered the Maxims, one for the bathroom skylight, and one for the living room. Got clear/grey/clear for both....
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 07-07-2014, 08:17 PM   #192
Rob
2014 25' International
Littleton , Colorado
Great detailed post. Although the skylight in my 2014 International Signature doesn't leak, this and other posts about leaking skylights make me wonder if it is just a matter of time. Right now, I'm more interested in insulating my skylight from the intense sun/heat as I travel the west.
Thinking of just going to Home Depot and getting a 19"x19" piece of stiff styrofoam to stick above the accordion blind during the day. Are their better solutions?
Best,
Rob
Best,
Rob
zenstream is offline   Reply With Quote
Old 07-08-2014, 10:51 AM   #193
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Best,
Rob
Yes.
Replace the cheap thin plastic junk that Airstream supplies, with Maxim skylights. Their three panel design will provide much better insulation than the OEM ones. Proper choice of tinting will provide even more protection from solar heating. Your suggested solution is also not necessarily going to be that effective. Your insulating panels will have to be essentially air tight sealed withing the skylight frame, or the air circulation will negate the insulating properties of the Styrofoam. Also, I can envision having to pluck little statically charged Styrofoam balls off the interior of the trailer after every insertion or removal.
Ken
IMO, a 2014 (or for that matter any) Airstream deserves a more elegant and permanent solution than you have suggested.
Old 07-08-2014, 08:03 PM   #194
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
In my old skylights I used a reflective material. I got one of those reflectors that people use in their windshields while parked in the sun. I cut that to fit tightly, then closed the blind. It helped!
Alan
Old 08-26-2014, 12:35 PM   #195
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
I just finished installing two Maxims on my 7 year old Airstream, yipeeeee. The bathroom skylight was leaking, and we cant have that. Time will tell, but these appear to be way superior to the original skylights. At least I know they will not crack and leak around each screw holding them in place. Trust me you new Airstream owners, your skylights are cracked around every screw holding them.
Thanks Kevin, great instructions.
ID:	219883   Click image for larger version
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Old 08-26-2014, 08:48 PM   #196
Ag&Au's Avatar
Thanks a lot for posting the pictures of your work platform. I will use that idea next time I work on the roof.
Ken
oem skylights, replace
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 10:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 08:49 PM
Step by Step Repair for 1965 Caravel jlovelady Steps 2 12-19-2009 03:23 PM
Skylights on 75 sovereign bdbluegrass Roof Vents, Skylights & Fans 5 08-21-2006 08:26 PM
Skylights..... Silvertwinkie Our Community 4 08-14-2003 09:32 AM
